zvivered
2018.3 : Launch R5 right after system.bit loaded
How can I make sure R5 start running only after system.bit is loaded ?
My system.bit and ELF for R5 are both in my BOOT.BIN.
Thank you,
Zvika
aravindb
HI @zvivered
Please create a BOOT.BIN using this below bif file. It should work.
//arch = zynqmp; split = false; format = BIN
the_ROM_image:
[fsbl_config]a53_x64
[bootloader]zynqmp_fsbl.elf
[destination_cpu = pmu]pmufw.elf
[destination_device = pl]system.bit
[destination_cpu = r5-0]app.elf
Thanks & regards
Aravind
aravindb
HI @zvivered
the_ROM_image:
Thanks & regards
Aravind
