2019.1 How do I add development packages, such as openssl-dev and curl-dev, to the Yocto build environment
I have a zcu102 development board. I am trying to add development packages to the build system but am unclear how to do that. Searching through various forums, I find conflicting approaches... none of which works. The failure that I see is a compile error in my code, where I'm trying things like #include <openssl/evp.h>
I have managed to add packages, such as openssl and curl, to the image that I've built.
Never mind... this is an issue with my code
