swig
ATLAS linear algebra libraries
I need to use ATLAS (linear algebra) libraries as part of application running under Petalinux. The set must be compiled for Cortex A53 based on ZCU104. Cross compiling from source is quite complicated and there is problem with fortran parameter. Do you know if there is a way how to get already compiled libs?
hokim
How about using openblas?
https://community.nxp.com/docs/DOC-340953
