aantonie
AXI DMA test error on zynqmp with fpga manager
Hi all,
I'm working with custom board similar to zcu102 and i'm using vivado 2018.2 with petalinux 2019.1.
I'm trying to build simple axidma petalinux system with axidmatest module but i have problems  when i'm trying to use also fpga-manager.
After modprobe axidmatest there is a lot of errors:
root@test:~# modprobe axidmatest
[ 82.986030] dmatest: Started 1 threads using dma16chan0 dma16chan1 [ 83.254873] dma16chan0-dma1: dstbuf[0x4d] not copied! Expected c2, got 32 [ 83.261656] dma16chan0-dma1: dstbuf[0x4e] not copied! Expected c1, got 31 [ 83.006386] dma16chan0-dma1: srcbuf[0x95a] overwritten! Expected c5, got 35
[ 83.013348] dma16chan0-dma1: srcbuf[0x95b] overwritten! Expected c4, got 34
---- ---- [ 85.317913] src_off=0x1f08 dst_off=0x27e0 len=0x1530 [ 85.327846] dma16chan0-dma1: terminating after 5 tests, 5 failures (status 0)
Below there is block design, zynq ps-pl configuration, axidma ip configuration and address editor.
System-user.dtsi (fpga-manager enabled):
/include/ "system-conf.dtsi"
	axidmatest_0: axidmatest@0 {
		compatible ="xlnx,axi-dma-test-1.00.a";
and pl.dtsi
/dts-v1/;
/plugin/;
	fragment@0 {
		target = <&fpga_full>;
		overlay0: __overlay__ {
			#address-cells = <2>;
			#size-cells = <2>;
			firmware-name = "dma_test_wrapper.bit.bin";
			resets = <&zynqmp_reset 116>;
	fragment@1 {
		target = <&amba>;
		overlay1: __overlay__ {
			afi0: afi0 {
				compatible = "xlnx,afi-fpga";
				config-afi = < 0 1>, <1 1>, <2 0>, <3 0>, <4 0>, <5 0>, <6 0>, <7 0>, <8 0>, <9 0>, <10 0>, <11 0>, <12 0>, <13 0>, <14 0xa00>, <15 0x000>;
			clocking0: clocking0 {
				#clock-cells = <0>;
				assigned-clock-rates = <99999000>;
				assigned-clocks = <&zynqmp_clk 71>;
				clock-output-names = "fabric_clk";
				compatible = "xlnx,fclk";
	fragment@2 {
		target = <&amba>;
		overlay2: __overlay__ {
			#size-cells = <2>;
			axi_dma_0: dma@a0000000 {
				#dma-cells = <1>;
				clock-names = "s_axi_lite_aclk", "m_axi_sg_aclk", "m_axi_mm2s_aclk", "m_axi_s2mm_aclk";
				clocks = <&zynqmp_clk 71>, <&zynqmp_clk 71>, <&zynqmp_clk 71>, <&zynqmp_clk 71>;
				compatible = "xlnx,axi-dma-7.1", "xlnx,axi-dma-1.00.a";
				interrupt-names = "mm2s_introut", "s2mm_introut";
				interrupt-parent = <&gic>;
				interrupts = <0 89 4 0 90 4>;
				reg = <0x0 0xa0000000 0x0 0x1000>;
				xlnx,addrwidth = <0x40>;
				xlnx,include-sg ;
				xlnx,sg-length-width = <0x17>;
				dma-channel@a0000000 {
					compatible = "xlnx,axi-dma-mm2s-channel";
					dma-channels = <0x1>;
					interrupts = <0 89 4>;
					xlnx,datawidth = <0x40>;
					xlnx,device-id = <0x0>;
				dma-channel@a0000030 {
					compatible = "xlnx,axi-dma-s2mm-channel";
					interrupts = <0 90 4>;
			psu_ctrl_ipi: PERIPHERAL@ff380000 {
				compatible = "xlnx,PERIPHERAL-1.0";
				reg = <0x0 0xff380000 0x0 0x80000>;
			psu_message_buffers: PERIPHERAL@ff990000 {
				reg = <0x0 0xff990000 0x0 0x10000>;
	fragment@3 {
		target = <&axidmatest_0>;
		overlay3: __overlay__ {
				dmas = <&axi_dma_0 0
					&axi_dma_0 1>;
				dma-names = "axidma0", "axidma1";
In petalinux using overlays i have successfully program fpga:
mkdir /configfs
mount -t configfs configfs /configfs
cd /configfs/device-tree/overlays/
echo 0 > /sys/class/fpga_manager/fpga0/flags
cp /run/media/mmcblk1p1/dma_test_wrapper.bit.bin /lib/firmware/
cp /run/media/mmcblk1p1/pl.dtbo /lib/firmware/
mkdir full
echo -n "pl.dtbo" > full/path
and everything looks fine
fpga_manager fpga0: writing dma_test_wrapper.bit.bin to Xilinx ZynqMP FPGA Manager
xilinx-vdma a0000000.dma: Xilinx AXI DMA Engine Driver Probed!!
but after inserting axidmatest module i there is a lot of errors:
[ 82.986030] dmatest: Started 1 threads using dma16chan0 dma16chan1 [ 82.992471] dma16chan0-dma1: srcbuf[0x958] overwritten! Expected c7, got 37 [ 82.999433] dma16chan0-dma1: srcbuf[0x959] overwritten! Expected c6, got 36 [ 83.006386] dma16chan0-dma1: srcbuf[0x95a] overwritten! Expected c5, got 35 [ 83.013348] dma16chan0-dma1: srcbuf[0x95b] overwritten! Expected c4, got 34 [ 83.020304] dma16chan0-dma1: srcbuf[0x95c] overwritten! Expected c3, got 33 [ 83.027259] dma16chan0-dma1: srcbuf[0x95d] overwritten! Expected c2, got 32 [ 83.034212] dma16chan0-dma1: srcbuf[0x95e] overwritten! Expected c1, got 31 [ 83.041164] dma16chan0-dma1: srcbuf[0x95f] overwritten! Expected c0, got 30 [ 83.048117] dma16chan0-dma1: srcbuf[0x960] overwritten! Expected df, got 2f [ 83.055069] dma16chan0-dma1: srcbuf[0x961] overwritten! Expected de, got 2e [ 83.062023] dma16chan0-dma1: srcbuf[0x962] overwritten! Expected dd, got 2d [ 83.068976] dma16chan0-dma1: srcbuf[0x963] overwritten! Expected dc, got 2c [ 83.075928] dma16chan0-dma1: srcbuf[0x964] overwritten! Expected db, got 2b [ 83.082880] dma16chan0-dma1: srcbuf[0x965] overwritten! Expected da, got 2a [ 83.089834] dma16chan0-dma1: srcbuf[0x966] overwritten! Expected d9, got 29 [ 83.096785] dma16chan0-dma1: srcbuf[0x967] overwritten! Expected d8, got 28 [ 83.103739] dma16chan0-dma1: srcbuf[0x968] overwritten! Expected d7, got 27 [ 83.110691] dma16chan0-dma1: srcbuf[0x969] overwritten! Expected d6, got 26 [ 83.117645] dma16chan0-dma1: srcbuf[0x96a] overwritten! Expected d5, got 25 [ 83.124599] dma16chan0-dma1: srcbuf[0x96b] overwritten! Expected d4, got 24 [ 83.131551] dma16chan0-dma1: srcbuf[0x96c] overwritten! Expected d3, got 23 [ 83.138511] dma16chan0-dma1: srcbuf[0x96d] overwritten! Expected d2, got 22 [ 83.145465] dma16chan0-dma1: srcbuf[0x96e] overwritten! Expected d1, got 21 [ 83.152416] dma16chan0-dma1: srcbuf[0x96f] overwritten! Expected d0, got 20 [ 83.159370] dma16chan0-dma1: srcbuf[0x970] overwritten! Expected cf, got 3f [ 83.166322] dma16chan0-dma1: srcbuf[0x971] overwritten! Expected ce, got 3e [ 83.173276] dma16chan0-dma1: srcbuf[0x972] overwritten! Expected cd, got 3d [ 83.180227] dma16chan0-dma1: srcbuf[0x973] overwritten! Expected cc, got 3c [ 83.187181] dma16chan0-dma1: srcbuf[0x974] overwritten! Expected cb, got 3b [ 83.194133] dma16chan0-dma1: srcbuf[0x975] overwritten! Expected ca, got 3a [ 83.201087] dma16chan0-dma1: srcbuf[0x976] overwritten! Expected c9, got 39 [ 83.208038] dma16chan0-dma1: srcbuf[0x977] overwritten! Expected c8, got 38 [ 83.215795] dma16chan0-dma1: 136632 errors suppressed [ 83.220966] dma16chan0-dma1: dstbuf[0x48] not copied! Expected c7, got 37 [ 83.227744] dma16chan0-dma1: dstbuf[0x49] not copied! Expected c6, got 36 [ 83.234530] dma16chan0-dma1: dstbuf[0x4a] not copied! Expected c5, got 35 [ 83.241310] dma16chan0-dma1: dstbuf[0x4b] not copied! Expected c4, got 34 [ 83.248088] dma16chan0-dma1: dstbuf[0x4c] not copied! Expected c3, got 33 [ 83.254873] dma16chan0-dma1: dstbuf[0x4d] not copied! Expected c2, got 32 [ 83.261656] dma16chan0-dma1: dstbuf[0x4e] not copied! Expected c1, got 31 [ 83.268435] dma16chan0-dma1: dstbuf[0x4f] not copied! Expected c0, got 30 [ 83.275214] dma16chan0-dma1: dstbuf[0x50] not copied! Expected df, got 2f [ 83.281994] dma16chan0-dma1: dstbuf[0x51] not copied! Expected de, got 2e [ 83.288772] dma16chan0-dma1: dstbuf[0x52] not copied! Expected dd, got 2d [ 83.295552] dma16chan0-dma1: dstbuf[0x53] not copied! Expected dc, got 2c [ 83.302330] dma16chan0-dma1: dstbuf[0x54] not copied! Expected db, got 2b [ 83.309110] dma16chan0-dma1: dstbuf[0x55] not copied! Expected da, got 2a [ 83.315888] dma16chan0-dma1: dstbuf[0x56] not copied! Expected d9, got 29 [ 83.322668] dma16chan0-dma1: dstbuf[0x57] not copied! Expected d8, got 28 [ 83.329447] dma16chan0-dma1: dstbuf[0x58] not copied! Expected d7, got 27 [ 83.336227] dma16chan0-dma1: dstbuf[0x59] not copied! Expected d6, got 26 [ 83.343005] dma16chan0-dma1: dstbuf[0x5a] not copied! Expected d5, got 25 [ 83.349785] dma16chan0-dma1: dstbuf[0x5b] not copied! Expected d4, got 24 [ 83.356563] dma16chan0-dma1: dstbuf[0x5c] not copied! Expected d3, got 23 [ 83.363343] dma16chan0-dma1: dstbuf[0x5d] not copied! Expected d2, got 22 [ 83.370121] dma16chan0-dma1: dstbuf[0x5e] not copied! Expected d1, got 21 [ 83.376902] dma16chan0-dma1: dstbuf[0x5f] not copied! Expected d0, got 20 [ 83.383682] dma16chan0-dma1: dstbuf[0x60] not copied! Expected cf, got 3f [ 83.390460] dma16chan0-dma1: dstbuf[0x61] not copied! Expected ce, got 3e [ 83.397238] dma16chan0-dma1: dstbuf[0x62] not copied! Expected cd, got 3d [ 83.404018] dma16chan0-dma1: dstbuf[0x63] not copied! Expected cc, got 3c [ 83.410796] dma16chan0-dma1: dstbuf[0x64] not copied! Expected cb, got 3b [ 83.417577] dma16chan0-dma1: dstbuf[0x65] not copied! Expected ca, got 3a [ 83.424355] dma16chan0-dma1: dstbuf[0x66] not copied! Expected c9, got 39 [ 83.431135] dma16chan0-dma1: dstbuf[0x67] not copied! Expected c8, got 38 [ 83.438719] dma16chan0-dma1: 136632 errors suppressed [ 83.444051] dma16chan0-dma1: #0: 273328 errors with [ 83.444055] src_off=0x958 dst_off=0x48 len=0x3088 ---- [ 85.317913] src_off=0x1f08 dst_off=0x27e0 len=0x1530 [ 85.327846] dma16chan0-dma1: terminating after 5 tests, 5 failures (status 0)
I have done test without fpga-manager and everything works fine.
system-user.dtsi without fpga-manager:
			&axi_dma_0 1>;
and axidmatest is working:
[   28.432545] dmatest: Started 1 threads using dma0chan0 dma0chan1
[   28.456685] dma0chan0-dma0c: terminating after 5 tests, 0 failures (status 0)
Does anyone known why axidmatest fails in system with fpga-manager enabled? Without fpga-manager everything is ok. Any ideas?
radheys
It seems the issue is related to overlay DT runtime ordering. Xilinx dma driver [1] assumes MM2S channel node is probed first.
But when fpga manager is enabled this channel load order is changed and s2mm channel is probed first.
In dmatest client [2] we provide a mapping. It works when MM2S channel is probed first so 0 is for TX.
But this assumption breaks when S2MM channel is probed first.
  • dmas: a list of <[DMA device phandle] [Channel ID]> pairs, where Channel ID is '0' for write/tx and '1' for read/rx channel.
Possible solution:
a) As a quick workaround in DTS we can swap the channel-id in dmas node. dmas = <&axi_dma_0 1 &axi_dma_0 0>;
Or we can modify axidmatest client driver and in dma_request_slave_channel change axidma0 -> axidma1 and vice-versa.
b) I am exploring on how we can fix this DT ordering dependency in a generic way and will send out an update.
[1] : DT node
axidma {
<snip>
{ compatible = "xlnx,axi-dma-mm2s-channel"; dma-channels = <0x1>; interrupts = <0 89 4>; xlnx,datawidth = <0x20>; xlnx,device-id = <0x0>; }
{ compatible = "xlnx,axi-dma-s2mm-channel"; dma-channels = <0x1>; interrupts = <0 90 4>; xlnx,datawidth = <0x20>; xlnx,device-id = <0x0>; }
[2] :
axidmatest_1: axidmatest@1
{ compatible ="xlnx,axi-dma-test-1.00.a"; dmas = <&axi_dma_0 0 &axi_dma_0 1>; dma-names = "axidma0", "axidma1"; }
radheys
Possible solution:
[1] : DT node
axidma {
<snip>
[2] :
aantonie
I have tested your workaround with swapped channels-id.
Changes in pl.dtsi are marked below
	fragment@3 {
					&axi_dma_0 0>;
And now it's working, so thank you for workaround.
