Access DMA from linux
i need to trans-fair some data from PS to PL, with Debian running on PS. As far as I know, since kernel 3.6, is the approach to use the Linux DMA API.
So i have to include dma-mapping.h or dmaengine.h in module or application.
My problem now is that in my petalinux build dir none of this files are present.
There is no files with dma, no dmaengine.h, dma-mapping.h or xilinx_dma.h ... except rdma in kernel include or rootfs /usr/include directory. But in the kernel 4.4  source are thoes files present and
In the kernel config alls options with the xilinx dma engine is enabled.
So what did go wrong in my build process, how do i get those DMA header files!?
Steve
Voyager
Voyager
Hey @steve-82,
While DMA is one way to transfer the data, there are a number of other ways as well ...
  • By using a memory mapped AXI slave
  • By reading the memory directly from the PL via one of the high performance busses
  • Via one of the PS peripherials with EMIO connections
  • Via EMIO GPIO
Best,
Herbert
-------------- Yes, I do this for fun!
I recently got DMA working with Petalinux 2015.4
My DMA inclusions are:
#include <linux/dmaengine.h>
#include <linux/dma-mapping.h>
Let me know if that helps.
Hi, recently I met the same problem I can't find those files
 Would you please give more details?
Can you tell us which version of petalinux you're using? (that matters)
Also, let us know how you're building your project. (I'm using the petalinux-build scripts)
I find the needed files in my build directory under:
<project-dir>/build/linux/u-boot/src/u-boot-plnx/arch/arm/include/asm/dma-mapping.h
I can't edit my last reply... so ...
It's also found in:
./components/linux-kernel/xlnx-4.0/arch/arc/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/microblaze/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/arm64/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/cris/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/parisc/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/metag/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/ia64/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/s390/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/sparc/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/xtensa/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/hexagon/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/tile/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/x86/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/powerpc/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/blackfin/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/frv/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/mn10300/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/openrisc/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/unicore32/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/nios2/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/sh/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/mips/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/m68k/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/alpha/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/c6x/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/avr32/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/arch/arm/include/asm/dma-mapping.h
./components/linux-kernel/xlnx-4.0/include/linux/dma-mapping.h
I'm using petalinux 2018.3, same as you I'm using the petalinux-build scripts
Did you do petalinux-build --sdk and petalinux-package --sysroot?
I was wondering how's your code will be like?
Did you generate sysroot and use it in sdk to cross compiler your code?
now I can find those linux/dmaxxxxx.h
but I'm facing several asm/asm-generic file include error
Ahh... well, I'm not on 2018.3 -- I was compiling from 2015.4.. so that's different (and in a big way).
Can you list for us the errors you're seeing when the build errors out?
 -Ben
asm/asm-generic file include issue
So it's like you generate sysroot and include it in sdk, then call linux/dmaxxxx.h and it worked?
how many path did you include in sdk?
my issue now seems like, some file need asm/xxxx.h but it's actually in asm-generic/xxxx.h
Not using the SDK at all. Have always just compile projects straight from commandline using "petalinux-build".
 -Ben
The workflow I'm using is like this
generate sysroot in petalinux --> include sysroot in vivado sdk --> coding --> cross compiler --> copy xxx.elf to baord --> run xxx.elf
So what the worlflow will be like if I use petalinux to build my code?
have you solved it please, i have the same problem
I'm using petalinux 2019.2
Samokaad,
What problem are you having exactly? (multiple items are discussed in this thread)
I also did not get the both of file in my petalinux 2020.1 whereas I built the petalinux as per the documentation of v2020.1.
I want to use DMA to transfer the data from my Custome IP to PL. but don't know what I am missing that I can not use it.
when I build the app using "petalinux-build -c myapp" command, myapp included
and main() function.
Some Error is:
ERROR: myapp-1.0-r0 do_compile: oe_runmake failed
ERROR: myapp-1.0-r0 do_compile: Execution of '/home/darpan/Downloads/Argon/project/ArastuSystemsOS/build/tmp/work/aarch64-xilinx-linux/myapp/1.0-r0/temp/run.do_compile.28048' failed with exit code 1:
aarch64-xilinx-linux-gcc -march=armv8-a+crc -mtune=cortex-a72.cortex-a53 -fstack-protector-strong -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=/home/darpan/Downloads/Argon/project/ArastuSystemsOS/build/tmp/work/aarch64-xilinx-linux/myapp/1.0-r0/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/darpan/Downloads/Argon/project/ArastuSystemsOS/build/tmp/work/aarch64-xilinx-linux/myapp/1.0-r0=/usr/src/debug/myapp/1.0-r0 -fdebug-prefix-map=/home/darpan/Downloads/Argon/project/ArastuSystemsOS/build/tmp/work/aarch64-xilinx-linux/myapp/1.0-r0=/usr/src/debug/myapp/1.0-r0 -fdebug-prefix-map=/home/darpan/Downloads/Argon/project/ArastuSystemsOS/build/tmp/work/aarch64-xilinx-linux/myapp/1.0-r0/recipe-sysroot= -fdebug-prefix-map=/home/darpan/Downloads/Argon/project/ArastuSystemsOS/build/tmp/work/aarch64-xilinx-linux/myapp/1.0-r0/recipe-sysroot-native= -c -o myapp.o myapp.c
myapp.c:1:10: fatal error: linux/dma-mapping.h: No such file or directory
1 | #include <linux/dma-mapping.h>
compilation terminated.
make: *** [<builtin>: myapp.o] Error 1
WARNING: exit code 1 from a shell command.
ERROR: Logfile of failure stored in: /home/darpan/Downloads/Argon/project/ArastuSystemsOS/build/tmp/work/aarch64-xilinx-linux/myapp/1.0-r0/temp/log.do_compile.28048
please help me with this. Thank You So Much in Advance.
@sandippatel
The Linux DMA API is not directly accessible from the userspace (i.e. your app). You would need to create a Linux driver to use the DMA API and then bridge this to your app via a standard userspace interface:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842418/Linux+DMA+From+User+Space
Ken Sloat - Embedded Software Engineer
https://www.designlinxhs.com
@sandippatel
What @ksloatdesignlinx says.
This is what I did.
my DMA driver lives in my kernel driver and I use IOCTLs to control the behavior.
There is also a VM space (as the wiki link describes) where my user-space application can access the DMA buffer directly without the Kernel->user Copy using something like read().
It works fabulously.
