Visitor polosatiy
Accessing PL AXI QSPI core in Linux on zc702
Hello!
Im trying to get access to AXI QSPI core and its drivers in Linux.
The problem is that i cant find it in /sys/ or in /dev/ and i have no idea vhere to look else and how to debug this.
Tools: Vivado+SDK 2014.4.
Board: zc702.
Design flow:
Hardware project in Vivado includes Zynq PS with SD0 for booting from SD card, UART1, and single AXI QSPI core.
Vivado's Chipscope and standalone sw project shows that AXI QSPI core works fine.
zynq2.pngNext, I prepare SD card for boot:
BOOT creation flow:
1) Linux used is http://www.wiki.xilinx.com/Zynq+2014.4+Release
2) FSBL is generated by SDK with -DFSBL_DEBUG_INFO flag.
3) BOOT.bin is also generated by SDK and includes FSBL from previous step, bitstream (exported from Vivado to SDK), and U-boot.elf from Linux release.
4) Device-tree is also generated by SDK. Default section about qspi is added in the end of dts:
	amba_pl {
		#address-cells = <0x1>;
		#size-cells = <0x1>;
		compatible = "simple-bus";
		ranges;
		axi_quad_spi@41e00000 {
			compatible = "xlnx,xps-spi-2.00.a";
			num-cs = <0x1>;
			reg = <0x41e00000 0x10000>;
5) SD card contains: boot.bin, devicetree.dtb, uImage, uramdisk.image.
6) Bootlog passes with no messages about AXI QSPI and its addresses, but Linux boots.
What am i doing wrong?
Observer kevin.jesse
Re: Accessing PL AXI QSPI core in Linux on zc702
My issue is I can't get a valid read from a fifo in PL. I had it working once not adding to the device tree. Your solution could help me too.
