Accessing PS GPIO through Petalinux
Hi All,
I would like to ask some help as I'm starting learning zynq petalinux.
I have a zynq zc702 rev1.1 development board to play with and looking into its schematic I found SW13/14 connected to PS bank 500. I've read somewhere in the internet that gpio connected in PS can be access directly without constraint, thinking this will be a good start.
I tried accessing the two buttons by using the given Xilinx-ZC702-v2015.2-final.bsp and edited the dts file and using http://svenand.blogdrive.com/files/gpio-uio-test.c as my test code which I got from https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/Using-generic-uio-with-PS-GPIO/m-p/643791#M9938
This is my system-top.dts file after adding @gpio0 referrence:
/dts-v1/;
/include/ "system-conf.dtsi"
  chosen
		bootargs = "console=ttyPS0,115200 earlyprintk uio_pdrv_genirq.of_id=generic-uio";
&clkc {
	fclk-enable = <0xff>;
&leds_4bits
 compatible = "generic-uio";
 xlnx,gpio-width = <0x20>;
 xlnx,all-inputs-2 = <0x20>;
 xlnx,is-dual = <0x1>;
&gpio0
  xlnx,all-inputs-2 = <0x1>;
  xlnx,gpio2-width = <0x2>;
  xlnx,tri-default-2 = <0xffffffff>;
  xlnx,gpio2-width = <0x20>;
&i2c0 {
	#address-cells = <1>;
... //more here
...// qspi last entry here
I build it, program it through jtag and it was successful, I saw uio0 and uio1, which I believed uio0 = &Leds_4bits and uio1 = &gpio0 from my dts above.
However, when I debug the code, I received zero's while SW13/14 is pressed.
I also changed in the code the offset from GPIO_TRI_OFFSET to GPIO2_TRI_OFFSET as well as the GPIO_DATA_OFFSET to GPIO2_DATA_OFFSET but got same result.
I know there is something that I've missed, but don't know where.
If you could help me point it out, that would be great.
This is the default pl.dtsi generated from the bsp (unedited):
 * CAUTION: This file is automatically generated by Xilinx.
 * Version: HSI
 * Today is: Mon Jul 13 05:19:46 2015
	amba_pl: amba_pl {
		#size-cells = <1>;
		compatible = "simple-bus";
		ranges ;
		leds_4bits: gpio@41200000 {
			#gpio-cells = <2>;
			compatible = "xlnx,xps-gpio-1.00.a";
			gpio-controller ;
			reg = <0x41200000 0x10000>;
			xlnx,all-inputs = <0x0>;
			xlnx,all-inputs-2 = <0x0>;
			xlnx,all-outputs = <0x1>;
			xlnx,all-outputs-2 = <0x0>;
			xlnx,dout-default = <0x00000000>;
			xlnx,dout-default-2 = <0x00000000>;
			xlnx,gpio-width = <0x4>;
			xlnx,interrupt-present = <0x0>;
			xlnx,is-dual = <0x0>;
			xlnx,tri-default = <0xFFFFFFFF>;
			xlnx,tri-default-2 = <0xFFFFFFFF>;
gee
I'm still not able to talk to ps gpio on my board, particularly the sw13/14 and ds12/23. I tried using the code from
https://forums.xilinx.com/xlnx/attachments/xlnx/ELINUX/12938/1/gpio_uio_app.c
I don't know what to put in my system-top.dts file. I tried this:
/dts-v1/;
  chosen
&clkc {
&axi_gpio_0
&gpio0
and modify the code to read the two buttons
while(1)
//determine which button was pressed regs = gpio_read(ptr, GPIO_DATA_OFFSET);//was GPIO_DATA2_OFFSET if(regs != 0) printf("Im getting something here. \n"); else printf("Nothing is coming. \n"); }
but still nothing I received.
I'm getting button presses in sw5/7 using GPIO_DATA2_OFFSET but nothing on sw13/14.
I also observed that sw5/7 won't interrupt if &gpio0 {}; is added in my dts file like above, why is that?
Hope someone can shade some light here.
thanks in advance
gee
Tags (2)
Ok, I found something in xilinx (http://goo.gl/IqlSB2) it uses DS12/23 SW13/14.
I copied the nodes to my zynq-7000.dtsi just below my gpio0 node.
And it works after I load it into the board, DS23 is blinking like a heartbeat.
My questions:
1. Can I make it into UIO (/dev/uiox) so I can create uio driver app for that using mmap instead of /sys/class/leds...?
2. I tried adding a single sub-node inside gpio-leds node, this time the DS12 to blink like heartbeat, why it doesn't blink at all, it stays off, see my .dtsi entry below?
gpio-leds
      compatible = "gpio-leds";
      led-ds12
        label = "led-ds12";
        gpios = <&gpio0 8 0>;
        default-state = "on";
        linux,default-trigger = "heartbeat";
      led-ds23
        label = "led-ds23";
        gpios = <&gpio0 10 0>;
3. It says, only the dts file to edit, what is the proper way or syntax to use so that I can put gpio-leds and gpio-keys node under amba in system-top.dts rather in zynq-7000.dtsi? I tried but it failed,  it says "ERROR: Failed to allocate 0x2000 bytes below 0x0" this error appear after boot up.
Hope someone can help me on this.
gee
After hours of research, the DS23 finally works using UIO, this is my dts now:
gpio0: gpio@e000a000 {
			compatible = "xlnx,zynq-gpio-1.0";
			#gpio-cells = <2>;
			clocks = <&clkc 42>;
			gpio-controller;
			interrupt-parent = <&intc>;
			interrupts = <0 20 4>;
			reg = <0xe000a000 0x1000>;
		gpio-leds
                  led-ds12
                    label = "led-ds12";
                  led-ds23
                    label = "led-ds23";
The above dts works only with DS23, DS12 will not blink I'm wondering if it has to do with the PS_MIO8_500 line pulled-up to VCCMIO.
Has anyone knows why DS12 can't be controlled in UIO?
Also, has anybody tried to control the two switches sw13 & 14 of zc702 board? What syntax did you use in dts? What properties did you add? On what node did you add it?
I tried putting the sample node gpio-keys just below the gpio-leds but it doesn't work.
I really appreciate if someone could help me on this.
gee
@gee
Have you verified the MIO8 configuration , check the link to configure MIO8 as GPIO so that i can used to control DS12 LED.
http://www.wiki.xilinx.com/Zc702+Linux
Reference DTS file for LED & SW on ZC702 https://github.com/cambridgehackers/adiboot/blob/master/dts-files/zynq-zc702.dtsi
Achutha
Hi achutha,
I'm very thankful for your reply. This is very helpful as a newbie to zynq.
Those two LEDS and two switches works when I used this: compatible = "gpio-leds" and compatible = "gpio-keys" using the demo application from http://www.wiki.xilinx.com/Linux+GPIO+Driver.
However, when I changed it to this compatible = "generic-uio" so I can use http://svenand.blogdrive.com/files/gpio-uio-test.c to both leds and switches, only DS23 works and the rest are like it doesn't exist on the board.
My questions:
1. When you say UIO application in accessing gpios does it mean you have to use only "generic-uio" as compatible?
2. I've read from the net that, it is not recommended to use /dev/mem instead use /dev/uioX, then use mmap(), how can I use it by not using "generic-uio" as compatible?
3. In pl.dtsi, I saw properties like xlnx,all-inputs, xlnx,all-inputs-2, xlnx,all-outputs, etc under axi_gpio, will these properties work if I put it in gpio@e000a000 node?
4. Is there any documents, that explains how to configure the dts, what properties to use on this node and not on that node, values to set and not to set, different kind of compatible string how it works, etc, particularly on zynq zc702?
gee
