Accessing PUF from Linux application?
I have previously worked with standalone applications on ZynqMP and have recently started to look at Petalinux.
My use case involves using the PUF and my research regarding Petalinux and PUF usage has given me... nothing what-so-ever :-).
Therefore, I'm hoping someone more informed can enlighten me regarding the following:
1. Is it possible to access the PUF from Linux and in such case, how?
2. If it is not possible to access the PUF from Linux, I suppose AMP is an alternative. Is shared memory the only way of communicating between a standalone and a Linux application?
I also saw something indicating that at least the crypto accelerators are accessible in Linux.
"Following are the new features added in PMU Firmware in 2017.3 release:
Added xilsecure API calls to support xilsecure functionality from Linux"
3. How can I access said xilsecure functionality in Linux?
@niklaslindskog
I am not sure why you can't see those pictures. I have attached the screenshot FYI.
@niklaslindskog
AES driver has been added since 2018.3 kernel.
You can check below link for more info.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/64749783/ZynqMP+AES+Driver
Longley
Thanks!
So from Linux I can use the PUF key but not access the PUF itself, is that correct?
@niklaslindskog
Yes, you can use PUF key to encrypt and decrypt data.
What do you want to do for accessing PUF itself?
That's a good start at least!
There are however two broken images on the page you linked to, maybe something to report to the page admin?
Without going into too much details - I want to be able to start and use the PUF without using bootheader options.
Using a standalone app enables access to the PUF also when booting via JTAG.
Therefore I am looking for something which provides the same functionality as XilSKey_Puf_Regeneration(XilSKey_Puf *InstancePtr).
The pictures displaying the kernel configuration on the AES driver wiki page are not showing.
Would it be possible to fix that?
@niklaslindskog
Thank you!
Got stuck and the upper picture made all the difference.
BTW, I don't think I am alone not seeing the pictures.
https://forums.xilinx.com/t5/Embedded-Linux/Using-HW-SHA-3-from-Linux/td-p/950530 has the same issue albeit a different accelerator.
