Participant rankeney
Accessing bare metal application memory from Linux
I have an AMP system based on XAPP1078 with Linux in the first 768M and the bare-metal application running in the remaining 256M. I want the Linux application to access some of the memory in the bare-metal application range, but am having problems. For example, I can create a variable in bare metal and print it's address and fill it with some value. When I try to peek that address (300198A8), I see 0. I even wrote a program to scan all 1G of memory for the pattern written by the bare-metal application but cannot find it. Linux clearly sees some memory at 0x30000000-0x3fffffff, but it isn't what the bare-metal application sees. Any idea what's going on?
FWIW, I'm using Petalinux 2014.4.
Kernel command line: console=ttyPS1,115200 earlyprintk maxcpus=1 mem=768M
In my system-conf.dtsi I have:
        memory {
               device_type = "memory";
               reg = <0x0 0x30000000>;
With reg = <0x0 0x40000000>; I saw the same result.
Do I need some additional device tree addition?
Thanks!
Re: Accessing bare metal application memory from Linux
FWIW, Xil_SetTlbAttributes(addr, 0x04de2); seems to do the trick for each page with a size of 0x00100000.
This is similar to what you do with OCM memory.
Looking back at XAPP1078 I suspect that the bsp makes the bare-metal memory non-sharable. Maybe there is some call to Xil_SetTlbAttributes() I can add to the bare-metal application to make some/all of the memory sharable?
Hi @rankeney
Regarding the linux memory configuration could you check the /proc/iomem file in your target machine? I'm not sure which of the properties DTS memory node or bootargs mem have preference when configuring the system, but definitibelly you need to map the memory addresses in your target to be able to access them.
Ibai
