Add python-pyelftools python package to Petalinux
I require the python-pyelftools for building a petalinux project running on a ZCU102 board.
Unfortunately, this package is not present inside /PetalinuxInstallDir/components/yocto/source/aarch64/layers/meta-openembedded/meta-python/recipes-devtools and thus cannot be added to petalinuxbsp.conf via
IMAGE_INSTALL_append = " \
python-pyelftools \
I've tried to manually copy a .bb recipe obtained from https://layers.openembedded.org/layerindex/recipe/60427/ in meta-python/recipes-devtools and then add this package inside petalinuxbsp.conf, but this didn't solve the issue.
Any help for solving the issue would be appreciated :)
Mathieu
Observer shustik
Re: Add python-pyelftools python package to Petalinux
O. I did:
go to petlnx_setup_dir/components/yocto/source/arm(I have arm 32 bit processor)/layers/
git clone -b rocko (my linx yocto version) --single-branch https://github.com/plihp/meta-measured.git (your package is in this layer)
then go to your project dir and enter
petalinux-config -> Yocto Settings -> User Layers --->
Enter petlnx_setup_dir/components/yocto/source/arm(I have arm 32 bit processor)/layers/meta-measured
Save and exit
To check adding of layer: your_proj_dir/build/conf/bblayers.conf. You should see here BBLAYERS:="\
.../meta-measured \
go to your project dir/project-spec/meta-user/recipes-core/images/petalinux-image-full.bbappend
and type to the end of petalinux-image-full file:
IMAGE_INSTALL_append = " pyelftools"
save
petalinux-config -c rootfs
user packages -> [*] pyelftools
save & exit
petalinux-build
it tells that can't find setuptools, but it understands where to find pyelftools
And now may be repeat with setuptools?
Observer shustik
I have the similar problem with rocko python-cycler... So right now I installed pip in my petalinux and use pip install cycler... Not very good idea but It works
Observer shustik
O. I did:
Save and exit
.../meta-measured \
save
save & exit
petalinux-build
Thank you very much for this detail answer.
I'm using Petalinux 2019.1 which relies on Yocto 2.6 (thud) and there is no meta-measured  layer for this version. I have managed to reproduce your steps by cloning a branch based on rocko, but the package remains not found during petalinux-build.
Does anyone has another suggestion to solve the issue ?
Observer shustik
Do you have internet connection on your board? Try use offline pip install pyelftools?
In my special use case (installation of OP-TEE 3.5.0 via https://github.com/OP-TEE/build), the pip solution is in my opinion not applicable.
I'm using OP-TEE 3.4.0 instead of 3.5.0, the 3.4 does not require pyelftools and hence build on Petalinux 2019.1 after a few adapation of the zynqmp build found on the OP-TEE/build github.
Thanks for the help, your solution can be a good guideline for people with a similar issue :)
Visitor asooy
I am also working with OP-TEE, with PetaLinux 2018.2 & 2018.3.
I was able to get OP-TEE building on 3.5.0 by locking it by tag OPTEE_VERSION="3.5.0" and SRCREV="5df2a985b2ffd0b6f1107f12ca2a88203bf31328" being its git commit id, in both its bb and bb appends. xtest also needs to be 3.5.0 and SRCREV="e4f6f76b4cb5763112f4722981f84a26f4ac7e55".
Just in the last few days i needed to use OP-TEE 3.6.0 because of the new ftrace tool. I was able to get OP-TEE 3.6.0 to build doing the following on ubuntu 16.04:
First fixed my python pip - $ sudo python3 -m pip uninstall pip && sudo apt install python3-pip --reinstall
Second install pyelftools - $ pip3 install pyelftools
Third -
$ petalinux-build -x clean
$ petalinux-build -x distclean
$ petalinux-build -x mrproper
After this i was able to build 3.6.0 with xtest passing.
OPTEE_OS bb/bbapend:
OPTEE_VERSION ??= "3.6.0"
SRCREV ??= "f398d4923da875370149ffee45c963d7adb41495"
OPTEE_TEST bb/bbapend:
SRCREV ??="40aacb6dc33bbf6ee329f40274bfe7bb438bbf53"
Tags (3)
