08-01-2017 07:03 AM
I am having trouble adding certain packages to a PetaLinux 2017.2 build. For example, when I need the "mount" command, I enable it in the menuconfig using petalinux-config -c rootfs and it becomes available from the Linux command line. That works fine, but some other packages don't seem to become available and I don't understand why.
Specifically, I'm now enabling the "ethtool" command, but when I try to call it from the Linux command line, I get "command not found". In case it was not in the path, I have tried to find it using find / -name "ethtool" but that does not return any results. When I search through the PetaLinux build files on my PC, I find the ethtool source code and object files, so I'm quite sure that it is getting included into the build. I have tried re-building and building from scratch several times.
I have also had the same problem with the "blkid" command.
Is there something that I should be doing that I'm not doing?
Jeff
11-22-2017 11:57 AM - edited 11-22-2017 11:57 AM
I have found the cause of my problem and I am documenting it here for anyone else who might have the same issue.
Firstly, I realized that ethtool (or whatever package) was not getting build into the rootfs by looking for it in the /images/linux/rootfs.tar.gz file. Knowing this allowed me to do some tests and stumble across my error pretty quickly.
I use a scripted build and my flow was the cause of my problem. Here were my steps:
petalinux-create --type project --template zynq --name project_name petalinux-config --get-hw-description <path-to-exported-hw> --oldconfig <copy meta-user recipe files into the project including /project-spec/configs/rootfs_config> petalinux-build
My mistake here was to assume that the PetaLinux tools would take my configuration files into account when I ran petalinux-build. In my experience, the tools actually do take most of the files into account using this method, but not the rootfs_config file. I found that in order for the tools to take the rootfs_config file into account, I needed to run petalinux-config again after copying the files into the project. Here is my new flow:
petalinux-create --type project --template zynq --name project_name petalinux-config --get-hw-description <path-to-exported-hw> --oldconfig <copy meta-user recipe files into the project including /project-spec/configs/rootfs_config> petalinux-config --oldconfig petalinux-build
Now I am able to find ethtool and all packages in the rootfs and call them from the command line as expected.
I hope this is useful to someone.
Jeff
08-03-2017 05:17 AM
Hi Jeff
Can you please try referring to this user guide to get some insight on adding packages to rootfs:
(Refer:- Steps to Build User Applications)
Kindly get back to me if you still faces the issues
Best Regards
Shabbir
08-03-2017 09:58 AM
Hi Shabbir,
Unfortunately the reference guide does not talk about adding packages from the menuconfig petalinux-config -c rootfs.
I am not trying to add a "user application", I am adding packages that are built into Linux. In the menuconfig, we can tick the packages that we want to include. I'm saying that when I tick certain applications, they don't actually get built into PetaLinux.
In the above image, I tick "util-linux-mount" so that I can use the "mount" command in PetaLinux. That works fine. But other packages don't seem to get built-in, even if I tick them - for example "ethtool" and "blkid".
Jeff
Jeff
