Observer davethetroll
App not copied into Linux image
I have followed the instructions in UG981 Petalinux Application Development Guide to add a test application "cpp_created" to a linux image.  I have created the app and configured the rootfs to include it.  When I make the image the messages imply that all is well
Including (most importantly, I assume)
[INFO ] install linux/rootfs/cpp_created.
However, when I boot into Linux on the MicroZed, there is no sign of cpp_created.  It does not exist in the /bin folder.
Am I right to expect to see it there?
Is there any known reason why it would not appear?
I'm using Vivado/XSDK and PetaLinux 2016.2.
Re: App not copied into Linux image
I discovered my problem.
First success.  When I tried booting this from SD card.  It worked.  The app was there in /bin and ran fine.
Previously I had been calling
petalinux-boot --jtag --prebuilt 3
, as this is the only thing I have found suggested in any of the bring up/getting started guides.
However, if I boot with
petalinux-boot --jtag --u-boot
or
petalinux-boot --jtag --prebuilt 2
then it all works correctly.
However, taking these options for --qemu fails to boot with "Card did not respond to voltage select!"
Can u post the .bb from your app?
.bb?
Where do I find that?
Searching some documents, I notice that the 2016.2 version of UG1144 makes no reference to .bb, the 2017.1 has many.
I'm guessing that is why I can't find any .bb.
What is the 2016.2 equivalent?
or
