Rono
BOOT.BIN
I was able to create a BOOT.BIN and image.ub using Petalinux and copied those files into an SD Card.
I inserted the SD card on my carrier board UltraZED-EV, but I get no response from the board.
I inserted an SD card that came with the card and that works.   How can I trace, why the BOOT.BIN and image.ub
I created does not boot up.
Prasanna_K
Hi @Rono ,
Try to enable debug prints in FSBL: This will give more details during boot. Update fsbl_%.bbappend file and add below content.
vi project-spec/meta-user/recipes-bsp/fsbl/fsbl_%.bbappend
XSCTH_BUILD_DEBUG = "1"
YAML_COMPILER_FLAGS_append = " -DFSBL_DEBUG_DETAILED"
Prasanna
-- Give Kudos if this is helpful and accept as solution if it solves your problem.
joancab
Mentor
Mentor
There are many potential reasons. One could be you didn't select the correct uart port in the configuration (petalinux-config). For some boards is uart0, others is uart1.
