gsm2019
Below is buliding linux for microzed board....How to slove the following issue ...its not building the linux for microzed board
sameer-gsm@sameergsm-desktop:~/xilinx/microzed_p/mz7020_fmccc_2018_2$ petalinux-build
[INFO] building project
[INFO] sourcing bitbake
INFO: bitbake petalinux-user-image
Loading cache: 100% |############################################| Time: 0:00:00
Loaded 3424 entries from dependency cache.
Parsing recipes: 100% |##########################################| Time: 0:00:03
Parsing of 2552 .bb files complete (2514 cached, 38 parsed). 3425 targets, 148 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |#######################################| Time: 0:00:06
Checking sstate mirror object availability: 100% |###############| Time: 0:00:22
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
WARNING: device-tree-xilinx+gitAUTOINC+f38738e568-r0 do_fetch: Failed to fetch URL git://github.com/xilinx/device-tree-xlnx.git;protocol=https;branch=master, attempting MIRRORS if available
ERROR: device-tree-xilinx+gitAUTOINC+f38738e568-r0 do_fetch: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-dVU8x9oQV1"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export GIT_SSL_CAINFO="/home/sameer-gsm/xilinx/petalinux/components/yocto/source/arm/buildtools/sysroots/x86_64-petalinux-linux/etc/ssl/certs/ca-certificates.crt"; export all_proxy="socks://192.168.5.1:3128/"; export ALL_PROXY="socks://192.168.5.1:3128/"; export no_proxy="localhost,127.0.0.0/8,::1"; export NO_PROXY="localhost,127.0.0.0/8,::1"; export ftp_proxy="ftp://manoj:manoj%40123@192.168.5.1:3128/"; export https_proxy="https://manoj:manoj%40123@192.168.5.1:3128/"; export http_proxy="http://manoj:manoj%40123@192.168.5.1:3128/"; export PATH="/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/recipe-sysroot-native/usr/bin/python3-native:/home/sameer-gsm/xilinx/petalinux/components/yocto/source/arm/layers/core/scripts:/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/recipe-sysroot-native/usr/bin/arm-xilinx-linux-gnueabi:/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/recipe-sysroot/usr/bin/crossscripts:/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/recipe-sysroot-native/usr/sbin:/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/recipe-sysroot-native/usr/bin:/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/recipe-sysroot-native/sbin:/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/recipe-sysroot-native/bin:/home/sameer-gsm/xilinx/petalinux/tools/hsm/bin:/home/sameer-gsm/xilinx/petalinux/components/yocto/source/arm/layers/core/bitbake/bin:/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/hosttools"; export HOME="/home/sameer-gsm"; git -c core.fsyncobjectfiles=0 remote add --mirror=fetch origin https://github.com/xilinx/device-tree-xlnx.git failed with exit code 128, output:
fatal: unable to access '/opt/petalinux/2018.2/sysroots/x86_64-petalinux-linux/etc/gitconfig': Permission denied
ERROR: device-tree-xilinx+gitAUTOINC+f38738e568-r0 do_fetch: Fetcher failure for URL: 'git://github.com/xilinx/device-tree-xlnx.git;protocol=https;branch=master'. Unable to fetch URL from any source.
ERROR: device-tree-xilinx+gitAUTOINC+f38738e568-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+f38738e568-r0/temp/log.do_fetch.4387
ERROR: Task (/home/sameer-gsm/xilinx/petalinux/components/yocto/source/arm/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_fetch) failed with exit code '1'
WARNING: linux-xlnx-4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0 do_fetch: Failed to fetch URL git://github.com/Xilinx/linux-xlnx.git;protocol=https;branch=xlnx_rebase_v4.14, attempting MIRRORS if available
ERROR: linux-xlnx-4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0 do_fetch: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-dVU8x9oQV1"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export GIT_SSL_CAINFO="/home/sameer-gsm/xilinx/petalinux/components/yocto/source/arm/buildtools/sysroots/x86_64-petalinux-linux/etc/ssl/certs/ca-certificates.crt"; export all_proxy="socks://192.168.5.1:3128/"; export ALL_PROXY="socks://192.168.5.1:3128/"; export no_proxy="localhost,127.0.0.0/8,::1"; export NO_PROXY="localhost,127.0.0.0/8,::1"; export ftp_proxy="ftp://manoj:manoj%40123@192.168.5.1:3128/"; export https_proxy="https://manoj:manoj%40123@192.168.5.1:3128/"; export http_proxy="http://manoj:manoj%40123@192.168.5.1:3128/"; export PATH="/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/sameer-gsm/xilinx/petalinux/components/yocto/source/arm/layers/core/scripts:/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/recipe-sysroot-native/usr/bin/arm-xilinx-linux-gnueabi:/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/recipe-sysroot/usr/bin/crossscripts:/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/recipe-sysroot-native/usr/sbin:/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/recipe-sysroot-native/usr/bin:/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/recipe-sysroot-native/sbin:/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/recipe-sysroot-native/bin:/home/sameer-gsm/xilinx/petalinux/components/yocto/source/arm/layers/core/bitbake/bin:/home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/hosttools"; export HOME="/home/sameer-gsm"; git -c core.fsyncobjectfiles=0 remote add --mirror=fetch origin https://github.com/Xilinx/linux-xlnx.git failed with exit code 128, output:
ERROR: linux-xlnx-4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0 do_fetch: Fetcher failure for URL: 'git://github.com/Xilinx/linux-xlnx.git;protocol=https;branch=xlnx_rebase_v4.14'. Unable to fetch URL from any source.
ERROR: linux-xlnx-4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/sameer-gsm/xilinx/microzed_p/mz7020_fmccc_2018_2/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/temp/log.do_fetch.389
ERROR: Task (/home/sameer-gsm/xilinx/petalinux/components/yocto/source/arm/layers/meta-xilinx/meta-xilinx-bsp/recipes-kernel/linux/linux-xlnx_2018.2.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2000 tasks of which 1608 didn't need to be rerun and 2 failed.
Summary: 2 tasks failed:
Summary: There were 2 WARNING messages shown.
Summary: There were 6 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
