noob1e
Boot fail while following zcu106 + ubuntu desktop article in wiki
The wiki article: https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/148668419/Zynq+UltraScale+MPSoC+Ubuntu+VCU+Gstreamer+-+Building+and+Running+Ubuntu+Desktop+from+Sources
Environment:
Ubuntu 18.04.1
Vivado 2019.1 (Updated)
Petalinux 2019.1
When I try to use prebuilt image with SD Card, it fails with red LEDs (INIT_B and PS_ERR_OUT?, attached)
I built my SD card with Win32DiskImager
The serial output is:
Xilinx Zynq MP First Stage Boot Loader
Release 2019.1   Jun 10 2019  -  09:24:58           // Every LED is green until here
Xilinx Zynq MP First S                                       // INIT_B and PS_ERR_OUT became red here
I thought there must be FPGA configuration step for HDMI and USB, but the wiki article doesn't have it and it only instructs to build linux image.
Is the article missing the step or I don't need to configure FPGA for linux work at all?
(So, the configuration step with hdf file do everything?)
I am trying to build the image myself now but not sure if it is the linux image problem.
Tags (2)
noob1e
Solution:
The new zcu106 I am using have different DRAM spec from older version.
Prebuilt image:
  It doesn't work because it is built with different DRAM spec.
Following the article:
  It doesn't work because it is configuring wrong DRAM spec during project.tcl. The design must be manually fixed.
  The petalinux-package command is wrong. It must include bit file
  petalinux-package --boot --fsbl images/linux/zynqmp_fsbl.elf --u-boot images/linux/u-boot.elf --pmufw images/linux/pmufw.elf --fpga images/linux/system.bit --force
Everything in this article is figured out by Jangsub, Makus engineer. Thanks.
aravindb
HI @noob1e
Can you please try with prebuilt images, which are present in "pre-built/linux/images/" path in petalinux project. This will help us to know is there any board issue or boot images issue.
Please download the BSP from this below link & follow below steps to create petalinux project :https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools/2019-2.html
petalinux-create --type project -s xilinx-zcu106-v2019.1-final.bsp
cd xilinx-zcu106-v2019.1
cd pre-built/linux/images/
Thanks & regards
Aravind
noob1e
Hi @aravindb
In conclusion, prebuilt images have no problem.
I did BIST test - successful.
I deployed prebuilt image using petalinux-boot --jtag - successful.
I deployed prebuilt linux image download from xilinx wiki with SD card - successful.
(I didn't tried the image in the petalinux subdirectory, but I believe this is same as the xilinx wiki one)
I also found other people experience similar problem.
https://forums.xilinx.com/t5/FPGA-Configuration/i-want-to-boot-Ubuntu-Desktop-on-ZCU106/td-p/1114895
This article shows almost same symptom I have.
I also tried boot image I built myself with the wiki article. But it also has same problem.
Do you have more advices?
Thank you a lot.
noob1e
Solution:
Prebuilt image:
