11-15-2009 01:18 AM
Since commit eedacbf0, drivers/serial/of_serial.c forces the
The following patch corrects the issue in what I believe is the right way:
diff --git a/drivers/serial/of_serial.c b/drivers/serial/of_serial.c
index 02406ba..78267af 100644
--- a/drivers/serial/of_serial.c
+++ b/drivers/serial/of_serial.c
@@ -161,7 +161,7 @@ static int of_platform_serial_remove(struct of_device *ofdev
static struct of_device_id __devinitdata of_platform_serial_table[] = {
{ .type = "serial", .compatible = "ns8250", .data = (void *)PORT_8250,
{ .type = "serial", .compatible = "ns16450", .data = (void *)PORT_16450
- { .type = "serial", .compatible = "ns16550", .data = (void *)PORT_16550
+ { .type = "serial", .compatible = "ns16550", .data = (void *)PORT_16550
{ .type = "serial", .compatible = "ns16750", .data = (void *)PORT_16750
{ .type = "serial", .compatible = "ns16850", .data = (void *)PORT_16850
#ifdef CONFIG_SERIAL_OF_PLATFORM_NWPSERIAL
11-16-2009 08:56 AM
I don't understand the problem completely, can you clarify?
Are you saying that we're ending up with a ns16550 driver which doesn't support FIFOs and we should be using a ns16550a driver which will use the FIFOs?
I don't see that this patch does anything, what am I not seeing as the 2 lines look the same?
11-19-2009 04:40 AM
Aiee... Something mangled my patch :smileysad:
It was supposed to be
+ { .type = "serial", .compatible = "ns16550", .data = (void *)PORT_16550A
Since the UART block reports (via openfirmware) that it is compatible with ns16550, yet the kernel's idea of 16550 conservatively assumes it has a buggy FIFO... (I gather some early 16550's did)
By announcing compatibility with ns16550A, we just tell the world our FIFO is working.
-az
11-19-2009 09:47 AM
Now I understand, and saw the other thread on the mailing list also.
