fsimjee
Build stress-1.0.4 for Petalinux
I would like to build the stress-1.0.4 tool for Petalinux. It is missing in Yocto so I would like to build it using the Petalinux tools. I was able to create an app template using this command:
petalinux-create -t apps -n stress-1.0.4 --enable
This created a folder: ./project-spec/meta-user/recipes-apps/stress-1.0.4/files that has a Makefile and stress-1.0.4.c file.
What should I do next? Can I drop in the package source files here?
Usually this package is installed like this:
./configure && make && sudo make install
fsimjee
Good catch, I didn't see the stress package in the yocto menu that comes up during petalinux-config. My source code folder is a little different so I added the package a little differently.
I added the stress package to the petalinux-image-full.bbappend file with this line:
IMAGE_INSTALL_append = " stress"
Then I ran "petalinux-config -c rootfs" to enable the package in the config menu.
hokim
petalinux has the recipe for stress
$ find /opt/petalinux/2018.3/components/yocto/source/aarch64/layers/ -name 'stress*'
/opt/petalinux/2018.3/components/yocto/source/aarch64/layers/core/meta/recipes-extended/stress
/opt/petalinux/2018.3/components/yocto/source/aarch64/layers/core/meta/recipes-extended/stress/stress_1.0.4.bb
Add stress to IMAGE_INSTALL and do petalinux-build
fsimjee
