Building custom BOOT.BIN without PetaLinux?
I am trying to build my own BOOT.BIN without having to depend on PetaLinux, since I currently building a lot of components (devicetree, ramdisk, etc) without using PetaLinux. Here are my boot.bif file and bootgen coomand which I used to generate BOOT.BIN file.
boot.bif file:
Image : {
   [bootloader]zynq_fsbl.elf
   system_top.bit
u-boot.elf [load=0x5a00000]devicetree.dtb [load=0x1000000]uramdisk.image.gz [load=0x6000000]uImage.bin // currently bootgen requires a file extens$ }
Command to generate BOOT.BIN:
bootgen -image boot.bif -o i BOOT.BIN -w -log
Once BOOT.BIN is generated, I am loading it into memory via JTAG with xmd commands. However, when I am trying to boot the system from u-boot, it fails with error that it can't get kernel image. Below is the u-boot error and the xmd script used to write BOOT.BIN into the memory to boot via JTAG.
Error:
zynq-uboot> bootm
Wrong Image Format for bootm command
ERROR: can't get kernel image!
zynq-uboot> bootm 0x6000000 0x1000000 0x5A00000
zynq-uboot>
Script:
connect arm hw
source fpga/ps7_init.tcl
ps7_post_config
ps7_init
#fpga -f fpga/system_top.bit
after 1000
dow -data "BOOT.BIN" 0x6000000
after 1000
dow "u-boot.elf"
con
Partition mismatch or partition ordering between u-boot and kernel may be one of the reasons. Can you also try verifying with the offsets and partitions ordering used in petalinux default configuration settings?
Naveen
Community Manager
Community Manager
It might be because of your bootm arguments. Check the definition of the "bootcmd" environment variable in u-boot.
