oanekingma
Building petalinux 2016.3 with Xilinx-ZC702-2016.3 SDK fails
I've installed petalinux 2016.3 on a 64 bit VM with 'CentOS Linux release 7.2.1511 (Core)'. All PetaLinux Tools Installation Requirements have been installed (with 'bc' missing from Table 1-1) as stated in UG1144. I then installed the BSP 'Xilinx-ZC702-2016.3' according to chapter 1 of UG1156.
However, when I try to rebuild the reference design system by calling 'petalinux-build' from the root of the SDK, the build fails when 'hsi' is being called. From the build.log file:
[INFO ] install sys_init
[ALL ] make INSTANCE=linux/rootfs/sys_init SUBSYSTEM=linux -C /home/oki/projects/test/Xilinx-ZC702-2016.3/build/linux/rootfs/sys_init install
[ALL ] make[2]: Entering directory `/home/oki/projects/test/Xilinx-ZC702-2016.3/build/linux/rootfs/sys_init'
[INFO ]
[ALL ] /home/oki/petalinux/etc/logging/log_progress: line 115: [: -le: unary operator expected
[ALL ] hsi -mode batch -source hsm/plnx-rootfs.tcl -notrace -nojournal -nolog -tclargs "get_uart_tty" "/home/oki/projects/test/Xilinx-ZC702-2016.3/subsystems/linux/config" "/home/oki/projects/test/Xilinx-ZC702-2016.3/build/linux/data/ipinfo.yaml" "/home/oki/projects/test/Xilinx-ZC702-2016.3/subsystems/linux/hw-description/system.hdf" "hw_info_file"
[ALL ]
[ALL ] ****** hsi v2016.3 (64-bit)
[ALL ] **** SW Build 1682563 on Mon Oct 10 19:07:26 MDT 2016
[ALL ] ** Copyright 1986-2016 Xilinx, Inc. All Rights Reserved.
[ALL ]
[ERROR] ERROR: [Common 17-217] Failed to load feature 'base'.
[ALL ] INFO: [Common 17-206] Exiting hsi at Thu Dec 8 08:40:53 2016...
[ERROR] make[2]: *** [hw_info_file] Error 1
[ALL ] make[2]: Leaving directory `/home/oki/projects/test/Xilinx-ZC702-2016.3/build/linux/rootfs/sys_init'
[ERROR] make[1]: *** [sys_init_install] Error 2
[ALL ] make[1]: Leaving directory `/home/oki/projects/test/Xilinx-ZC702-2016.3/build/linux/rootfs'
[ALL ] make: *** [sub_install_component_/none/rootfs/single/petalinux-rootfs] Error 2
[ALL ] make: Leaving directory `/home/oki/projects/test/Xilinx-ZC702-2016.3/build/linux'
[INFO ] config linux/kernel
Any idea on what might be going wrong?
oanekingma
[root@localhost bin]# ./hsi
INFO: [Common 17-206] Exiting hsi at Fri Dec  9 13:39:12 2016...
[root@localhost bin]# more hsi.log
# hsi v2016.3 (64-bit)
# SW Build 1682563 on Mon Oct 10 19:07:26 MDT 2016
# Start of session at: Fri Dec  9 13:39:12 2016
# Process ID: 9156
# Current directory: /home/oki/petalinux/tools/hsm/bin
# Command line: hsi -mode tcl
# Log file: /home/oki/petalinux/tools/hsm/bin/hsi.log
# Journal file: /home/oki/petalinux/tools/hsm/bin/hsi.jou
Apparently the problem lies somewhere in 'hsi' itself, but I can't figure out what or how...
jeffdaq
Are you sourcing any of the Xilinx setting files first?  You should be able to run hsi without doing any Xilinx setup.
jeff
pvenugo
I hope the prior command to petalinux-build i.e. $ petalinux-create -t project -s <bsp project location> executed appropriately
Also, could you make sure you are setting vivdao env?
Praveen
achutha
@oanekingma
Did you change the Petalinux/Vivado tool install directory after installing ?
Achutha
oanekingma
I've created a new Ubuntu 16.04 VM since CentOS did not seem to work and now I've managed to build Petalinux 2016.3. So at least I know I'm calling the correct scripts/commands etc... :) I would still like to have it work under CentOS 7.2 though, so if you have any comments, please let me know.
@jeffdaq: I'm sourcing the 'settings.sh' file, without a warning. Output below when calling 'hsi':
[root@localhost ~]# cd /home/oki/petalinux/
[root@localhost petalinux]# source /home/oki/petalinux/settings.sh
PetaLinux environment set to '/home/oki/petalinux'
INFO: Checking free disk space
INFO: Checking installed tools
INFO: Checking installed development libraries
INFO: Checking network and other services
[root@localhost petalinux]# cd tools/hsm/bin/
INFO: [Common 17-206] Exiting hsi at Mon Dec 12 09:43:27 2016...
@pvenugo:
Yes, the project-create command completed successfully. I'm not sure what you mean by 'could you make sure you are setting vivdao env?'. I've only installed Petalinux on this VM, not the SDK or Vivado.
@achutha:
No, I have not moved anything or changed anything in the project structure.
Best regards,
Oane
