ccdoss
Built Linux...Now what?
I have built Linux for Xilinx according to the instructions on http://xilinx.wikidot.com. I am using a ML405, and used the base configuration (DTS) that comes with the xilinx kernel.
I'd like to ultimately create apps that host USB devices through the Cypress USB controller. I see that the drivers are there in the kernel. However, I'm not sure how to make sure the kernel can see the EPC peripheral.
How do I create applications to interact with the peripherals on the board?
vneethv
If the driver is already present in the kernel, then u gotta write the app and put it as a part of the ramdisk.
then download the ramdisk and start working !!
ccdoss
Thank you for the response. I guess my next question is how does one create linux apps that use drivers. I've created apps before, but not that use drivers. I am guessing I may need to use embedded linux development. I have and am searching for some docs and tutorials on this, but any pointers you may have that could shorten the process would be greatly appreciated.
linnj
In my opinion now you should be buying some embedded linux books or finding some tutorials on the web as we can't teach all that in a forum.
If you go to free-electrons.com/docs they have a bunch of good tutorials.  I also recommend Embedded Linux Primer, the book.  There's a lot of information out there that will help, but it takes some digging.
ccdoss
Thank you for the free-electrons.com reference. I am going through the tutorials now. I do have one more question, though.
I've built the kernel, and have now built the requisite "hello world" application. How do I download the program to the board? Do I need to make it part of the kernel and/or ramdisk elf, or download it separately?
vneethv
you gotta download a ramdisk; put ur application anywhere in that ..and compile the simpleImage with ramdisk..or use the uramdisk..
once linux's up..u can simply browse to the application location from the shell and execute it,,
ccdoss
Okay, here's what I did:
  1. Created "helloworld.c" file.
  2. Compiled using ELDK commands: ppc_4xx-gcc -o hello helloworld.c
  3. Tried to execute hello on my Ubuntu system. It said it can't execute binary (expected since I cross compiled).
  4. Created a new file system by doing commands in box below.
  5. Before copying, I copied my hello executable to the /mnt/old-disk/bin directory.
  6. mv ramdisk.image.gz arch/powerpc/boot
  7. I then compiled the linux kernel and loaded onto the board.
  8. I looked in contents of bin directory, and was "hello" executable was there.
  9. I then cd /bin, and issued ./hello command. I received a command not found error.
What am I doing wrong?
    dd if=/dev/zero of=initrd.img bs=1M count=8
    mke2fs -F -v -m0 initrd.img
    mkdir /mnt/new-disk
    mount -o loop initrd.img /mnt/new-disk
    mkdir /mnt/old-disk
    gunzip ramdisk.image.gz
    mount -o loop ramdisk.image /mnt/old-disk
    cp -rf /mnt/old-disk/* /mnt/new-disk
    umount /mnt/old-disk
    umount /mnt/new-disk
    gzip -9 initrd.img
    mv initrd.img ramdisk.image.gz
mkdir /mnt/new-disk
vneethv
while compiling the helloworld.c use -statis keyword.
statically link the code..the libraries mightnt be available in ur ramdisk..! juz have a try..
vneethv
sorry..spelling mistake :)
i meant
ppc_4xx-gcc -o hello -static helloworld.c
ccdoss
WOW!! That worked!!! Of course, my helloworld program is 800K, but it works.
timo-ge
The next interesting point to me would be,  where to copy which libraries  to the ramdisk to avoid static linking.
