C ++ code compatiblity wtih ARM Cortex A53 in XCZU4EG with other A-53 processor
We have some C++ code used to run in another ARM Cortex-A53 processor(Rapsberry Pi 3B+), we hope to move that C++ code into XCZU4EG (also ARM Cortex-A A53) side.
These C++ code purely computation within ARM A-53 processor nothing to do with peripheral devices, only run for some vision algorithm based on ARM Compute Library,which is said to only rely on ARM NEON Instruction set.
Can these A -53 code be reused in XCZU4EG A-53 processor?
aravindb
HI @tomshan_MATLAB
Yes, you ca run the  same compiled C++ code for both the boards as long as  if you you are using the same toolchain for building C++ application & Linux, rootfs on both the boards.
Thanks & regards
Aravind
aravindb
HI @tomshan_MATLAB
Thanks & regards
Aravind
