ngerber
Cache coherency when using mmap with different drivers on Linux
I have a bit more general question concerning how to maintain cache coherence in a Linux userspace application when using mmap'ed memory regions and different Linux device drivers. Can you confirm the following statements? (Please read "volatile pointer" as "pointer pointing to volatile data" and all the mapping is done with the MAP_SHARED flag.)
  • UIO device driver: As the driver maps the memory without processor cache, there is no need to cast the pointer returned by mmap to a volatile pointer. Is it be good practice to cast it nevertheless? Would there be any differences between using a volatile pointer and just a pointer?
  • /dev/mem:
    - Read: As the caches are enabled, any read must occur on a volatile pointer, otherwise outdated data might be read.
    - Write: There are two options; either the data is written to volatile pointers to force the write through or the data is written using a normal pointer but after finishing writing, msync with the MS_SYNC flag has to be called to force the device to flush the cached data to the memory. Is one of the two ways better than the other?
  • PCI device: Same behaviour as /dev/mem
Best regards,
Nicola
divcesar
what I can tell is that "volatile variables" aren't directly related to caching. It is related to compiler optimizations. More specifically, when you have a volatile variable or pointer, you are telling the compiler to not hold that value in a register because there might be other actors in the system trying to access (i.e., change) that variable concurrently. Keeping the variable in a register would prevent actors from seeing changes of each other.
