zeshanali
Can i use the OpenCV library in SDK and run on FPGA virtex 5 PowerPC
Hello all.
I write an application of image processing ,application dependant on opencv libraries ,how i can use the opencv libraries in our application on SDK  that run on PowerPC,or its is possible or not,
Please have any ideas  share me.
Thanks Advance:
jpl@xiphos.ca
Gidday there,
I have not used OpenCV code within the XPS SDK, but I have developed code for Linux on the Virtex-4 PowerPC using pretty much stock openCV 1.1.  You just have to build it with the appropriate ./configure --host=powerpc-405-linux-gnu settings and make sure your cross-compiler is not far.
I hope this helps.
Joshua
