Can't see Hello World - Ug1209 and ZCU102
I am using ZCU102.
HW-Z1-ZCu102 - Rev 1.1
I am following https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug1209-embedded-design-tutorial.pdf
I am not able to get 'hello world' shown at page 28.
I checked all four UARTs,
Only message I got on other UART was:
"!! Press ESC to enter System Controller mode"
One difference i found was part name as shown in the picture
In Ug1209, it is ending at "i" -- Figure 2-13 at page 24
You can see the figure attached with this message.  It is ending at "e"
Not sure, it can make difference or not. But I have not able to get hello world message.
Re: Can't see Helo World - Ug1209 and ZCU102
Just checked sticker on the board
It says 0432055-05-1940
According to this :  https://www.xilinx.com/support/answers/37579.html
I have production silicon
Re: Can't see Hello World - Ug1209 and ZCU102
I digged little more and figured out:
https://forums.xilinx.com/t5/Xilinx-Evaluation-Boards/Hello-World-Application-on-ZCu102-REV-1-0-not-working/m-p/1042983
I am trying to run using both v2019.1 and v2018.3
But not able to run with anyone at the moment.
Another Update:
I am able to get Hello World.
Following helped a lot
https://www.xilinx.com/support/answers/72210.html
Method: (using SDK 2018.3)
1. I downloaded petalinux BSP from
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools/2018-3.html
ZCU102 BSP (prod-silicon)  (BSP - 588.33 MB)
MD5 SUM Value : 4caff226eecd17e4db68ed1bcab1ff21
2. extracted HDF file from that
Created a new SDK project and pointed to that HDF as hardware description
3.  Followed: https://www.xilinx.com/support/answers/72210.html
Created new FSBL and new Hello_World projects.
4. Downloaded 72113-files.zip  from
https://www.xilinx.com/support/answers/72113.html
Replaced xfsbl_ddr_init.c, xfsbl_hooks.c, xfsbl_hooks.h file in fsbl "src" directory.
5. Carried out Clean and new Compile
6. created new run configuration.. for fsbl
Unchecked Run "psu_init" as descrined in https://www.xilinx.com/support/answers/72210.html
7. Then ran new run configuration from Hello_world
Checked "PL powerup"
It all looks kind of hacky.
Not sure, how to proceed forward.
Should I never check psu_init in future?
Always replace those files in FSBL?
How about I bring a new PL project from Vivado? what RAM values should i set?
