Cannot change CSU Multi Boot address from U-Boot
we want to change the Multiboot address (csu_multi_boot) from U-Boot to start a golden image (e.g. if the user wants a recovery update) but we cannot access the CSU registers.
As far as I understand is the problem the wrong Exception Level (EL). Is there an easier way to start a fallback BOOT.BIN from U-Boot? We don't want to skip loading ATF(bl31.elf) in the bootsequence.
By the way, in Linux the change of the desired register works fine:
echo 0xffca0010 0xff 0xA0 > /sys/firmware/zynqmp/config_reg
[running with Petalinux 2019.1]
Thanks & Regards,
H.
@hbachmann Sorry i missed out one point previously.
We need to add Multi boot register access in PMU as below, along with the above U-Boot change.
 File: pm_mmio_access.c, in pmAccessTable add the below entry.
/* CSU Mulitboot register */
.startAddr = PM_MMIO_CSU_BASE + 0x10, //0xFFCA0010,
.endAddr = PM_MMIO_CSU_BASE + 0x10,
.access = MMIO_ACCESS_RW(IPI_PMU_0_IER_APU_MASK |
IPI_PMU_0_IER_RPU_0_MASK |
IPI_PMU_0_IER_RPU_1_MASK),
Rebuild PMUFW, flash bootbin.
Sudhakar
@hbachmann , Yes, you understanding is correct. U-boot is running at EL2 Non-Secure that cannot access the secure register(PMU/CSU) .
And I am not aware of an easy way to program multiboot register from u-boot unless you hack into u-boot and PMUFW to enable access to this register.
To update Multi Boot register from u-boot, try below option.
Try using "zynqmp_mmio_read" and "zynqmp_mmio_write", include "#include <asm/arch/sys_proto.h>"
#define REGISTER_MULTIBOOT_ADDR 0xFFCA0010
zynqmp_mmio_write(REGISTER_MULTIBOOT_ADDR,0xFF,0xA0);
H.
Sudhakar
Thanks Sudhakar!
