Cannot find the ADV7511 device driver in my linux
I have built the kernel with the ADV7511, and when I connected my screen with HDMI cable, the screen show the linux system normally.But!!! I can't find the ADV7511 driver, the /dev list in my system is shown as below:
I need to operate the driver node, so how can I do to find the adv7511 driver?
Re: Cannot find the ADV7511 device driver in my linux
Thanks for your reply, and I figured it out. the device node is named /dev/fb0 in the linux, I write images in it successfully.
ADV7511 driver is from Analog Devices, regards HDMI video output driver.
Basically showing device name is depends on the driver file , if we are adding it Kernel , extra function should call for adding as device node , which it will show as /dev/adv7511 , & /bus, /sys part of Linux Device policy (Name of Device, Type of Bus, Bus name using container_of macro).
Giving you the reference how to add the ADV7511 to Xilinx Zynq Boards, please check the same.
https://wiki.analog.com/resources/tools-software/linux-drivers/platforms/zynq
Provide Kudos if post is helpful.
Thanks & Regards
Satish G
G Satish Kumar
