Cannot start DMA channel
     I am trying to read data using a v4l2 driver. I believe I have configured correctly the vdma parameters(width, height, stride, etc) as the VDMA hw expects.
     I see in examples from Xilinx SDK that other that frame parameters and enabling interrupts there is no much vdma configuration(using XAxiVdma API)  before writing/reading data.
    However after dmaengine_submit call I get the following error:
xilinx-vdma 43000000.dma: Cannot start channel 9f6dda10: 18831
    It would appear that some of the errors are EOL or SOF but I don't think it should be the case.
    What other settings should be configured before working with Xilinx VDMA?
Best regards,
         Mihaita
Re: Cannot start DMA channel
     Does anybody know possible reasons for getting DMA slave error: XILINX_DMA_DMASR_DMA_SLAVE_ERR ?
     It seems is the only DMA error I get that makes the channel halt(the others are maskable)
    In the  vdma IP UG fromXilinx it is stated  that the slave responds with SLVERR on memory map interface.
     How could I figure out exactly why that happens?
       Mihaita
Voyager
Voyager
   Thanks for the advice. i tried that already but the vdmatest module is not loaded,. i have added in dts like the documnetion explains and vdma version is the same as the one in the driver, but the module is still not loaded.
Best regards,
         Mihaita
     I do not know how to run the vdmatest client actually:
     I have the vdma node:
/sys/bus/platform/devices/amba_pl:vdmatest@0
/sys/devices/soc0/amba_pl/amba_pl:vdmatest@0
/sys/firmware/devicetree/base/amba_pl/vdmatest@0
    and looked at the vdmatest.c source but could not figure out how to run the test.
    Any suggestions?
        Mihaita
