dannier
Change image.ub from xilinx-zcu102-v2019.1-final.BSP but import overlay fail, do i lose steps? device tree?
Originally, i can run following python code in jupyter on board zcu102 successfully by step1 ~ step3. but i replace kernel by step4 ~ step8 to run python code again, then it fail.
step 1: create download BSP and rootfs as below command
-- bash ~/PYNQ/sdbuild/scripts/image_from_prebuilt.sh zcu102 ~/PYNQ/boards/zcu102/xilinx-zcu102-v2019.1-final.bsp aarch64 ~/PYNQ/bionic.aarch64.2.5.img
step 2: write image to sd card.
 -- sudo dd if=./zcu102-2.5.img of=/dev/sdh bs=4M status=progress
step 3: write python code (as below) to test my bitstream.
==========python code in jupyter===================
from __future__ import print_function
import sys
sys.path.append('/home/xilinx')
from pynq import Overlay
from pynq import Bitstream
from pynq import allocate
import numpy as np
from pynq.lib.dma import *
from pynq import MMIO
from cffi import FFI
ffi = FFI()
Ol = Overlay("/home/xilinx/bit-DPR-addsubprd/DPR_add_sub_prd.bit")
step 4: create project from my BSP
~/xilinx-zc102-2019.1$ petalinux-create -t project -s <path-to-bsp>
step 5: change rootfs from ramdisk to sd card
~/xilinx-zc102-2019.1$petalinux-config ==> Image Packaging Configuration
step 6: build
~/xilinx-zc102-2019.1$petalinux-build
step 7: replace image.ub in 1st partition of my sd card by new image.ub in project-path/images/linux/image.ub
step 8: boot from sd card with new kernel and run python code again but fail as below
-----------------------------------jupyter error stack on zcu102----------------------------------------
RuntimeError Traceback (most recent call last)
<ipython-input-1-4d920c81e03f> in <module>()
4 import socket
5 sys.path.append('/home/xilinx')
----> 6 from pynq import Overlay
7 from pynq import Bitstream
8 from pynq import allocate
/usr/local/lib/python3.6/dist-packages/pynq/__init__.py in <module>()
31 from .uio import UioController
32 from .xlnk import Xlnk
---> 33 from .pl import PL
34 from .ps import Register
35 from .ps import Clocks
/usr/local/lib/python3.6/dist-packages/pynq/pl.py in <module>()
37 from multiprocessing.connection import Client
38 from .mmio import MMIO
---> 39 from .ps import CPU_ARCH_IS_SUPPORTED, CPU_ARCH, ZYNQ_ARCH, ZU_ARCH
40 from .devicetree import DeviceTreeSegment
41 from .devicetree import get_dtbo_path
/usr/local/lib/python3.6/dist-packages/pynq/ps.py in <module>()
320
321
--> 322 class _ClocksUltrascale(_ClocksMeta):
323 """Implementation class for all Zynq Ultrascale PS and PL clocks
324 not exposed to users.
/usr/local/lib/python3.6/dist-packages/pynq/ps.py in _ClocksUltrascale()
380
381 if CPU_ARCH_IS_SUPPORTED:
--> 382 IOPLL_CTRL = Register(CRL_APB_ADDRESS + IOPLL_CTRL_OFFSET)
383 RPLL_CTRL = Register(CRL_APB_ADDRESS + RPLL_CTRL_OFFSET)
384
/usr/local/lib/python3.6/dist-packages/pynq/registers.py in __init__(self, address, width, debug, buffer)
113 if buffer is None:
114 from .mmio import MMIO
--> 115 array = MMIO(address, np.dtype(register_type).itemsize).array
116 elif hasattr(buffer, 'view'):
117 array = buffer
/usr/local/lib/python3.6/dist-packages/pynq/mmio.py in __init__(self, base_addr, length, debug, device)
81 if device is None:
82 from .pl_server.device import Device
---> 83 device = Device.active_device
84 self.device = device
85 print("mmio base_addr " + hex(base_addr))
/usr/local/lib/python3.6/dist-packages/pynq/pl_server/device.py in active_device(cls)
89 if not hasattr(cls, '_active_device'):
90 if len(cls.devices) == 0:
---> 91 raise RuntimeError("No Devices Found")
92 cls._active_device = cls.devices[0]
93 return cls._active_device
RuntimeError: No Devices Found
what steps do i lose? thanks for help!
dannier
xlnk driver default is not enabled, that help with memory management, accelerator control, and data movement among other things. to enable driver and device tree as below.
> petalinux-config -c kernel
  (1) Device Drivers → Staging drivers → Xilinx APF Accelerator driver (ON)
  (2) Device Drivers → Staging drivers → Xilinx APF Accelerator driver → Xilinx APF DMA engines support (ON)
 - Add device tree fragment for APF driver
  (1) add path: <>/project-spec/metauser/recipes-bsp/device-tree/files/system-user.dtsi
  (2) add content:
            xlnk {
           compatible = "xlnx,xlnk-1.0";
dannier
  (2) add content:
            xlnk {
