Change tftpboot directory
When building a PetaLinux image using the command petalinux-build the result is automatically copied to the /tftpboot directory. Is there a setting to change to another directory?
Sven
Anonymous
Not applicable
There is a file called config in <proj-dir>/subsystems/linux. modify the "CONFIG_SUBSYSTEM_TFTPBOOT_DIR" value to the desired directory.
