Compiling Peta linux with custom FPGA
I compiled petalinux successfully with default FPGA bit file. Now I want to build petalinux with custom FPGA file.
I need inputs to build how to build custom FPGA to generate images, to build this is it required to install Vivado SDK and Xilinx_SDK_2018.1_0405_1_Lin64.bin
Please suggest.
Umamahesh
Re: Compiling Peta linux with custom FPGA
Hi @umamahesh,
You need to use below commands if you are using custom hdf.
$ petalinux-create -t project -n <porject_name> --template zynq
$ petalinux-config --get-hw-description=<PATH_TO_HDF>
If you are using ZC702 Eval board using your own hdf.
$ petalinux-config ---> DTG Settings ---> (zc702) MACHINE_NAME
$ petalinux-config ---> u-boot Configuration  ---> (zynq_zc702_config) u-boot config target
Sandeep
Hi @umamahesh,
Yes you need Vivado tools to be installed.
  1. Generate the hdf(include bitstream) refer UG1209.
  2. Build petalinux using your hdf refer UG1144.
Sandeep
Participant rsey
This is also a good source if you don't have time to go through UG1209 and UG1144.
https://www.slideshare.net/shtaxxx/debian-linux-on-zynq-setup-flow-vivado-20154
P.S. But be careful at page 41, ps7_cortex9_0 should be ps7_cortexa9_0.
\Razi
\Razi
-- Don’t forget to Reply, Kudo, and Accept as Solution --
Hi Sandeep,
I got a custom fpga bit file from FPGA team, I downloaded xilinx-zc702-v2018.1-final.bsp (for Zynq 7020).
I created petalinux as shown below
petalinux-create -t project -s xilinx-zc702-v2018.1-final.bsp
To build petalinux with custom fpga, I run as follows
petalinux-config --get-hw-description=<path to hdf file>
Following is the error
INFO: Getting hardware description...
WARNING: Usage of HDF is going to be deprecated in future releases.Please use DSA(Device Support Archive) instead.
INFO: Rename cmt_som_design_wrapper.hdf to system.hdf
[INFO] generating Kconfig for project
ERROR: [HDF 64-4] /home/petalinux/xilinx-zc702-2018.1/project-spec/hw-description/system.hdf is not valid Hardware Handoff File
ERROR: [Hsi 55-1451] Error: running open_hw_design.
ERROR: Failed to generate /home/petalinux/xilinx-zc702-2018.1/build/misc/config/Kconfig.syshw
ERROR: Failed to Kconfig project
ERROR: Failed to generate System hardware Kconfig file.
Please suggest asap.
Umamahesh
Hi @umamahesh,
Sandeep
