Scholar beandigital
Compiling an app in SDK with missing libs
I have created an empty Linux project in SDK 2018.2. I am running SDK in Windows 10. I am using a file that has the following libs
#include <unistd.h>
#include <fcntl.h>
#include <libudev.h>
When I try and compile I get warnings on the first two and an error on the last. How would I resolve this? Do I need to get the include files and then point to them? Trouble is that I am working in Windows and these are Linux files. Thanks
Re: Compiling an app in SDK with missing libs
Hi @beandigital,
XSDK doesn't provide all the linux package libraries to use in applications now you have two options.
  1. Build the petalinux sdk(petalinux-build --sdk) and then use the libraries using XSDK
  2. Create applications using recipes and include all the build dependency libraries and packages.
Sandeep
Scholar beandigital
Hi @sandeepg
I am a bit confused :). I have Vivado and SDK on my Win 10 machine. I then have a VM running Ubuntu that has Petalinux on it. I have got Linux running on my board and managed to create a Hello World in SDK (on Win 10) that I can run on the board. So do I need to run SDK on Ubuntu to get the libs working? Or can I do something to use the libs with SDK on Win 10?
Ok, so the flow you would use is (as Sandeep mentioned) in Petalinux to generate the sysroots is:
  • petalinux-build --sdk
  • petalinux-package --sysroot
    • This will place the sysroots folder in the images/linux folder in your petalinux project directory
If you are using the SDK in Windows, then you would need to copy this folder (sysroots) local to your windows machine
Then to create a Linux Application in SDK:
File -> New -> Application Project
In the Linux System Root point to the aarch64-xilinx-linux folder (assuming this is Zynq Ultrascale):
Then either use the Hello World template, or Empty application and import your source code.
Right click on your application, and add the --sysroot Linker flag:
Then add any supporting libraries (for example here I am using the RFDC so I needed the libmetal, and rfdc and math libs):
Let me know if this helps?
Scholar beandigital
Thanks for the explanation, I will give it a go and let you know,
Scholar beandigital
When I try to copy the sysroots folder I get errors :-
There was an error copying the file into /mnt/hgfs/Shared/sysroots/x86_64-petalinux-linux/lib.
error making symbolic link operation not supported
Scholar beandigital
I seemed to have solved the problem by just zipping the dir. I have created a new project and added the path of the sysroot. But I am still having issues with some header files. I am trying to use <linux/dma-mapping.h> but it cant find it.
Scholar beandigital
Does nobody know how to fix this problem? If I look in my project directory for the Linux project the files seem to be there. Also if I create a new project using the SDK, it says that the sysroot dir should be ../sysroot/stage. But there isnt a stage directory.
Newbie milessmith
i was  facing the same problem. but now Thank you so much for this. I was into this issue and tired to tinker around to check if its possible but couldnt get it done. Now that i have seen the way you did it, thanks guys
with
regards
Visitor russellsnow
Petalinux --sdk always fails
 Cloning into '/scratch/rds/projs/desperate_try3/build/tmp/work/x86_64-nativesdk-petalinux-linux/nativesdk-qemu-xilinx/v2.11.0-xilinx-v2018.1+gitAUTOINC+1d5516986e-r0/git/capstone'...
|   GEN     hw/mem/trace.h
| fatal: Unable to look up git.qemu.org (port 9418) (Name or service not known)
| fatal: clone of 'git://git.qemu.org/capstone.git' into submodule path '/scratch/rds/projs/desperate_try3/build/tmp/work/x86_64-nativesdk-petalinux-linux/nativesdk-qemu-xilinx/v2.11.0-xilinx-v2018.1+gitAUTOINC+1d5516986e-r0/git/capstone' failed
| Failed to clone 'capstone'. Retry scheduled
| Cloning into '/scratch/rds/projs/desperate_try3/build/tmp/work/x86_64-nativesdk-petalinux-linux/nativesdk-qemu-xilinx/v2.11.0-xilinx-v2018.1+gitAUTOINC+1d5516986e-r0/git/ui/keycodemapdb'...
|   GEN     hw/i386/trace.h
| fatal: clone of 'git://git.qemu.org/keycodemapdb.git' into submodule path '/scratch/rds/projs/desperate_try3/build/tmp/work/x86_64-nativesdk-petalinux-linux/nativesdk-qemu-xilinx/v2.11.0-xilinx-v2018.1+gitAUTOINC+1d5516986e-r0/git/ui/keycodemapdb' failed
| Failed to clone 'ui/keycodemapdb'. Retry scheduled
|   GEN     hw/i386/xen/trace.h
| Failed to clone 'capstone' a second time, aborting
| ./scripts/git-submodule.sh: failed to update modules
| Unable to automatically checkout GIT submodules ' ui/keycodemapdb capstone'.
| If you require use of an alternative GIT binary (for example to
| enable use of a transparent proxy), then please specify it by
| running configure by with the '--with-git' argument. e.g.
|  $ ./configure --with-git='tsocks git'
| Alternatively you may disable automatic GIT submodule checkout
| with:
|  $ ./configure --disable-git-update'
| and then manually update submodules prior to running make, with:
|  $ scripts/git-sbumodule.sh update  ui/keycodemapdb capstone
|   GEN     hw/9pfs/trace.h
| make: *** [Makefile:39: git-submodule-update] Error 1
Hi @russellsnow,
The qemu nativesdk errors are due to your network proxy settings are not configure please check your proxy settings.
Sandeep
Visitor chcase
Are there any options for this error if I don't have any network access on the build machine?
