Voyager
Voyager
Configure NAND partitions
Hi Hall,
We have successfully flash our NAND from JTAG & Xilinx SDK. So my question about NAND address.
I would like to work with this simple schema first:
Flash “partitions”
### nand-partition 0 ###
FSBL
File: fsbl.elf
Start address: 0x0
Size: 0x100000 = 4 blocks = 1 MB
### nand-partition 1 ###
U-boot
File: u-boot.elf
Start address: 0x100000
Size: 0x400000 = 16 blocks = 4 MB
### nand-partition 2 ###
U-Boot environment
Start address: 0x500000
Size: 0x40000 = 1 block = 256 kB
### nand-partition 3 ###
kernel Linux kernel
File: uImage
Start address: 0x540000
Size: 0xA00000 = 40 blocks = 10 MB
### nand-partition 4 ###
dtb Compiled device tree blob
File: devicetree.dtb
Start address: 0xF40000
### nand-partition 5 ###
Ramdisk1
File: uramdisk1.image.gz
Start address: 0xF80000
Size: 0x1400000 = 80 blcks = 20 MB
### nand-partition 6 ###
Ramdisk2
File: uramdisk2.image.gz
Start address: 0x2380000
### nand-partition 7 ###
Factory UBIFS root file system
File: factory.ubifs
Start address: 0x3780000
According to the part table I configured BOOT.bin file like that:
the_ROM_image:
    [bootloader]C:\fsbl.elf
    C:\u-boot-.elf
    [offset = 0x540000, load = 0x3A00000]C:\uImage.bin
    [offset = 0xF40000, load = 0x3900000]C:\standalone.dtb
    [offset = 0xF80000, load = 0x2000000]C:\uRamdisk1.image.gz
    [offset = 0x2380000, load = 0x2000000]C:\uRamdisk2.image.gz
    [offset = 0x3780000, load = 0x2000000]C:\factory.ubifs
So everything seems good on the NAND device and we are able to boot kernel with uramdisk1 and uramdisk2.
OK what's wrong ? Now i would like to update u-boot (from u-boot himself or Linux user-space, loaded from SDcard) without erase the others NAND parts, but what's u-boot start address on the NAND ?
Best regards,
Trigger
Tags (2)
