Configure U-Boot on Petalinux and build project
Hi everyone,
I have been able to create a project and build it on Petalinux 2017.3, and run it on a TE0729 from Trenz (Zynq 7020).
Now I want to add/enable some command lines  like imls or flinfo on U-Boot for debugging purposes by running:
$ petalinux-config -c u-boot
I select some commands I want to use in the menu that appears.
But when saving and trying a new build ($ petalinux-build), it won't allow it and complains about /tmp/yocto files with the following warning coming up hundreds of times:
warning: backslash and newline separated by space
And the following final error:
ERROR: Task (/opt/Xilinx/Petalinux/2017.3/components/yocto/source/arm/layers/meta-xilinx/recipes-bsp/u-boot/u-boot-xlnx_2017.01.bb:do_compile) failed with exit code '1'
I can attach the full message log if needed.
Anything I am missing here?
Thanks for your support.
          The proper way to configure U-boot using petalinux is through C pre-processor configs. Please use the steps in UG1144 on pg 76 for more information on how to use the CONFIG to set up these.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug1144-petalinux-tools-reference-guide.pdf#page=76
Please mark an answer "Accept as solution" if a post has the solution to your issue.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_3/ug1144-petalinux-tools-reference-guide.pdf#page=78
Its on page 78 in UG1144 v2017.3
Please attach the log file, which could help in pointing to exact failure/issue
Best Regards
Shabbir
Thanks both for your reply.
Attached is the log file of the build.
I followed the steps describes and added following line in platform-top.h:
#define CONFIG_CMD_IMLS
then saved the file and tried to compile with $ petalinux-build -c u-boot
but I have the same errors and the build fails.
Is there anything to do in the ncurses menu after running $ petalinux-config -c u-boot ?
I was going through the error log, and found this:- error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function)
Try to define this flag
#define CONFIG_SYS_MAX_FLASH_BANKS    1
Alternatively, follow the section "Using External Kernel and U-Boot With PetaLinux" to let the petalinux to load uboot externally, if you assume the uboot source is working properly
Best Regards
Shabbir
Hi Shabbir,
This still didn't work. This is how my platform-top.h now looks like:
#include <configs/platform-auto.h>
#define CONFIG_SYS_BOOTM_LEN 0xF000000
/*Required for uartless designs */
#ifndef CONFIG_BAUDRATE
#define CONFIG_BAUDRATE 115200
#ifdef CONFIG_DEBUG_UART
#undef CONFIG_DEBUG_UART
#endif
#endif
I'm not sure I understand the fact that it actually looks straightforward to enable imls through petalinux-config  like other options you would select with the space bar marking the option with a star, but in fact it is simply not possible to do so.
I have attached the new log of building after changing platform-top.h.
Thank you
Did you get this fixed?
No I didn't.
Instead I went on having a separate U-Boot source that I would compile externally from Petalinux.
Hope this helps.
