Create zImage for ZynqMP
Is it possible to compile linux kernel for Zynqmp to get zImage as a result.
Normal process is
make ARCH=arm64 xilinx_zynqmp_defconfig
make ARCH=arm64
This will result in Imag file at the output
I want to have zImage which can be obtained in any other linux build by
make ARCH=arm64 zImage
But when I run "make ARCH=arm64 zImage" for zynqMP configuration, I get error "No rule to make target zImage".
If it is not possible, My goal at the end to get uImage. How to get uImage then from Image then?
Any Help Please
Re: Create zImage for ZynqMP
Hi @moibrahim,
Simple:
$ sudo apt install u-boot-tools
$ mkimage -A arm -T kernel -C none -n Linux -d zImage uImage
  • -A [architecture]
  • -T [image type]
  • -C [compression type]
  • -n [image name]
  • -d [image data file]
Cheers,
Trigger
@triggerThanks for your input
But as you mentioned, You have provided zImage to mkimage utility. That is why I asked first for zImage.
I tried also
mkimage -n 'Kernel Image' -A arm64 -O linux -C none -T kernel -a 0x8000 -e 0x8000 -d Image uImage
But when trying to boot using bootm, I got system is freezing at "starting Kernel" as shown below bootmuImage.png
So I thought problem in my uImage
P.S., I have passed bootargs correctly to the kernel
@moibrahim
Why do you want zImage ?
[EDIT]: give us your cmdline
[EDIT]: Are you sure about the kernel entry point ?
Cheers,
Trigger
@trigger
*** Why do you want zImage ?
I wanted to find other way to get uImage, I thought may be getting it from zImage is the possible way
*** give us your cmdline
console=ttyPS0,115200 rw earlyprintk rootwait root=/dev/mmcblk1p2
*** Are you sure about the kernel entry point ?
yep, I just posted a quick screenshot and command format in my previous post (not matching I know). But in reality i provided the same address and entry point
@moibrahim,
1) You can build direct an uImage from kernel sources no? (like Zynq)
2) are you sure about ttyPS0 ?
3) we need more info becausei'm not sure that's the correct load address
@trigger
Can you please try in your side: the following script
#! /bin/sh -e
## Cross Compiler
export CROSS_COMPILE=<<<add here path to your cross compiler >>>
git clone https://github.com/Xilinx/linux-xlnx.git
cd linux-xlnx
make ARCH=arm64 -j4 uImage
@moibrahim
Sorry but i cannot spend time on it today,
I will made a test tomorrow ;)
Cheers,
Trigger
You can't build zImage for ZynqMP devices. Only Image and uImage is the supported formats.
Sandeep
@sandeepg
Thx for the info it's good to know :)
Problem solved.
Cheers,
Trigger
@sandeepg
How then to build the uImage,
is it using "make uImage" or using "mkimage"
P.S: I tired "make ARCH=arm64 uImage", it gives error that no rule to make target uImage
