Newbie sohu_wj
DMA module compilation
I'm currently running a Debian LInux on my Zynq ZC706. I've already made a bare-metal program which configures DMAs on PL, and now I'm trying to migrating this design into Linux system. But I got totally lost in this part.
I found two designs from Github:
1.https://github.com/dhytxz/zynq-linux-dma
2.https://github.com/bmartini/zynq-xdma
The first demo uses PetaLinux to compile the DMA device module, however, I just found that the kernel version running on my board is different from those of PetaLinux.
The uImage of my system is based on this one:
https://github.com/analogdevicesinc/linux.git
And the version is 3.18.0, which is different from the kernel version of PetaLinux.
Therefore, I wrote a simple Makefile in my Linux directory to compile the dma.c, but got some errors indicating the missing of XILINX_DMA_DEVICE_ID_SHIFT. I modified the .c file to add in the code defining this parameter as 28 (I copied this one from https://github.com/Xilinx/linux-xlnx/blob/master/include/linux/amba/xilinx_dma.h) and passed the compilation of .ko file, but failed when using the insmod on my Zynq device.
I got the same error message for the second design.  Could anyone offer me some help on this problem? Thanks a lot!
Best Regards,
Jay
Newbie sohu_wj
Re: DMA module compilation
I've solved this problem by replacing the Linux kernel. I used the kernel files from Xilinx and it now works. Thanks!
Best,
Jay
git clone https://github.com/analogdevicesinc/linux.git
cd linux
make menuconfig
-> device drivers
-> [*] DMA Engine support
[*] Xilinx DMA Engines
this should cause the xilinx dma modules to be compiled.As for the compilation error, I doubt the kernel version is the problem. A #include is probably missing.
G.W.,
NIST - Time Frequency metrology
Newbie sohu_wj
Thanks. I checked this, and my kernel has already included the Xilinx DMA driver. I just downloaded the 3.15 Linux Kernel from Xilinx, and I'm working on compiling it to make a new uImage instead of my old one. I'll update the progress and post here.
Jay
Newbie sohu_wj
Best,
Jay
Visitor kate_sch
Hi Jay,
in your first msg you sad, you run Debian Linux on zc706.
May i ask you where did you find Debian for Zynq??? (maybe some links)
Thanks!
Kate
