DMA w Petalinux say : Unable to prepare the dma engine for the DMA transmit buffer
I'm trying to use DMA w Petalinux, I have a kernel device driver from
https://github.com/bperez77 , I allocated a lot of CMA , 60 MB and the installed the module:
axidma: axidma_dma.c: axidma_dma_init: 718: DMA: Found 1 transmit channels and 1 receive channels.
axidma: axidma_dma.c: axidma_dma_init: 720: VDMA: Found 0 transmit channels and 0 receive channels.
my DMA has SG enabled and loop back M_AXIS_MM2S to S_AXIS_S2MM , IRQs connected but I see them :
48:          0          0     GIC-0  41 Edge      f8005000.watchdog
 49:          0          0     GIC-0  61 Level     xilinx-dma-controller
 50:          0          0     GIC-0  62 Level     xilinx-dma-controller
IPI1:          0          0  Timer broadcast interrupts
my component is
root@peta64v2:~# cat /proc/iomem
00000000-3fffffff : System RAM
  00008000-008fffff : Kernel code
  01800000-01862143 : Kernel data
40400000-4040ffff : /amba_pl/dma@40400000
e0001000-e0001fff : xuartps
and the device tree is:
/include/ "system-conf.dtsi"
amba_pl: amba_pl {
        #address-cells = <1>;
        #size-cells = <1>;
        compatible = "simple-bus";
        ranges ;
        axidma_chrdev: axidma_chrdev@0 {
                compatible = "xlnx,axidma-chrdev";
                dmas = <&axi_dma_0 0 &axi_dma_0 1>;
                dma-names = "tx_channel", "rx_channel";
        axi_dma_0: dma@40400000 {
            #dma-cells = <1>;
            clock-names = "s_axi_lite_aclk", "m_axi_sg_aclk", "m_axi_mm2s_aclk", "m_axi_s2mm_aclk";
            clocks = <&clkc 15>, <&clkc 15>, <&clkc 15>, <&clkc 15>;
            compatible = "xlnx,axi-dma-1.00.a";
            interrupt-names = "mm2s_introut", "s2mm_introut";
            interrupt-parent = <&intc>;
            interrupts = <0 29 4 0 30 4>;
            reg = <0x40400000 0x10000>;
            xlnx,addrwidth = <0x40>;
            xlnx,sg-length-width = <0xe>;
            dma-channel@40400000 {
                compatible = "xlnx,axi-dma-mm2s-channel";
                dma-channels = <0x1>;
                interrupts = <0 29 4>;
                xlnx,datawidth = <0x40>;
                xlnx,device-id = <0x0>;
            dma-channel@40400030 {
                compatible = "xlnx,axi-dma-s2mm-channel";
                interrupts = <0 30 4>;
                xlnx,device-id = <0x1>;
I changed the positon of the client axi_dma_0 in the device tree to the bottom at some point.
The driver and the App are compile outside the petalinux using makefile. When I try to run the testbench I get this
XI DMA Benchmark Parameters:
    Transmit Buffer Size: 7.91 MiB
    Receive Buffer Size: 7.91 MiB
    Number of DMA Transfers: 1000 transfers
Using transmit channel 0 and receive channel 1.
Failed to perform the AXI DMA read-write transfer: Device or resource busy
dmesg
axidma: axidma_dma.c: axidma_prep_transfer: 236: Unable to prepare the dma engine for the DMA transmit buffer.
cma: cma_release(page eff91000)
cma: cma_release(page eff81000)
I wonder if there is anything to do the IRQ since it is not happening ,
the truth is, I need any Device Driver to work with my Petalinux dma.
Tags (3)
Participant jiv4ik
Re: DMA w Petalinux say : Unable to prepare the dma engine for the DMA transmit buffer
What value of properties "Width of Buffer Length Register" in the AXI DMA IP  do you have? If it is less than 23 then the buffer is not enough.
it is 14 ! I am changing to 23
thank you.
