jackfrye11
Device Tree Won't Build
Hey I am trying to add a Crystal Oscillator device to my QEMU Zynq 7100 PS emulation as documented by UG1169 p 46. The device in my PetaLinux project is as follows
/dts-v1/;
/include/ "system-conf.dtsi"
&i2cswitch{
        i2c@0 {
                #address-cells = <1>;
                #size-cells = <0>;
                reg = <0>;
                si570_21 clock-generator@5d {
                        compatible = "silabs,si57x";
                        reg= <0x5d>;
                        temperature-stability=<50>;
in the file <petalinux-root>/project-spec/meta-user/recipes-dt/device-tree/files/system-top.dts
This is the build error:
Error: /home/epi/jfrye_xilinx/project10242017p1e2016.4/petaproject/build/../components/plnx_workspace/device-tree-generation/system-top.dts:10.12-13 syntax error
I do not have a ton of experience with device tree. If anyone can spot the improper syntax, I would greatly appreciate it.
Tags (2)
jackfrye11
Having done some research on the format of device trees, it is obvious that the i2cswitch block outside the first set of brackets needs to be inside the brackets. That is the syntax error.
jackfrye11
