Device tree interrupt number for PL-PS interrupt
In the Zynq MPSoC technical reference manual (p. 306), I see that the IRQ for PL interrupt 0 is 121. However, in the auto-generated device tree from Xilinx I found that it was using IRQ 89. At first I thought this might have been a bug, but after searching around for a bit, I found this post in the Xilinx support forums:
https://forums.xilinx.com/t5/Embedded-Linux/mapping-irq-number-into-device-tree-value/td-p/697418
That post says that you have to add 32 to the number in the device tree to arrive at the IRQ listed in the TRM. Sure enough, 89 + 32 = 121, so all is well.
However, what's not clear to me is how was I supposed to know that I needed to add this magical number 32? I've read through the Interrupts section of the TRM a few times now and haven't found anything that mentions this. I also read the blog post linked in the forum post above where he also mentions this offset of 32, but the question remains -- how did the blog post author know about the 32 offset?
I am obviously missing something, perhaps something obvious. Can anyone help clear this up for me?
Re: Device tree interrupt number for PL-PS interrupt
Hi @greande ,
Generally Shared peripheral interrupts has their own ids starts from 32.
System has reserved interrupt id's from 0-31(private interrupts). SPI's can be routed to cpu or PL. So the IRQ number mentioned is SPI(specific to peripheral) id. To achieve the actiual IRQ id you have to add 32 to the interrupt number in device tree. you can refer GICv2 document for better understanding the interrupt numbers
Best Regards
Kranthi
Hi @greande ,
Best Regards
Kranthi
