Device tree system-user.dtsi, not building
I am trying to allocate some reserved memory in petalinux as in the wiki/confluence page;
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841683/Linux+Reserved+Memory
I have a project based on the ZCU111 (RFSoC eval), i have added a modified 'system-user.dtsi' as shown in the wiki/confluence page this appears to compile and i can boot the image,  however this image when booted does not show reservered memory using command;
'cat /proc/iomem.'
Injecting syntax errors in the system.dtsi does not cause errors when i run "petalinux-build -c device-tree" , however "petalinux-build -b device-tree" does causes errors (as expected due to the syntax errrors)., but i'm unsure how to build this 'system.dtb' into the 'image.ub'
The project doesn't appear to always be including system-user.dtsi?
Any pointers on what is going wrong or what to try.
Tim
Also, you can always quickly compile the DT if you are making changes here as running through the tools can be time consuming:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/136904764/Creating+Devicetree+from+Devicetree+Generator+for+Zynq+Ultrascale+and+Zynq+7000
cd <plnx proj>/components/plnx_workspace/device-tree/device-tree
gcc -I ../../../../project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi -E -nostdinc -undef -D__DTS__ -x assembler-with-cpp -o my_dts/system-top.dts.tmp system-top.dts
dtc -I dts -O dtb -o system-top.dtb system-top.dts.tmp
Once you are happy, then as Sandeep says:
  • petalinux-build -c device-tree -x cleanstate
It appears the running "petalinux-build -c device-tree" build on first build and includes "system-user.dtsi" file.
Subsequent rebuild using "petalinux-build -c device-tree" does not rebuild even if changes to the "system-user.dtsi" file have been applied.
I am forced to do a "petalinux-build -x mrproper" to clean the project, then rebuild using "petalinux-build".
Is this expected behaviour of the petalinux tools?
Tim
Hi @tmonaghan84 ,
Whenever you add nodes to system-user.dtsi you need to run cleansstate.
$ petalinux-build -c device-tree -x cleansstate
With this it should generate the right nodes and you no need to run "petalinux-build -x mrproper"
Once you run any bitbake recipe for example in this case it's "device-tree" you can verify the list of task executed in log.task_order file
$ cat <TMPDIR>/<PROJECT_NAME>/work/<YOCTO_MACHINE_NAME>-xilinx-linux/device-tree/xilinx+gitAUTOINC+73e546e312-r0/temp/log.task_order
Sandeep
should be
   I have the exact same problem. However even after I run "petalinux-build -c device-tree -x cleanstate" and "petalinux-build -x mrproper" the problem persists in both cases. I know that system-user.dtsi does not get processed because I created syntax error in it on purpose. Petalinux builds and runs through just fine without calling out the error. What else could keep Petalinux not to process the updated system-user.dtsi?
thanks,
Simon
Can you share your hdf/xsa and your system-user.dtsi?
   Thank you for the quick response. Attached are the requested files. Basically the design is based on the HDMI_RX from the ZCU106 TRD. I added in my own custom design on the HDMI transmit side which I don't plan on be part of the video framework. Then I borrowed the vcu_10g.dtsi from the TRD with some modifications to make my own system-user.dtsi. You will see the system-user.dtsi has injected error in it as I mentioned before.
Simon
There are alot of syntax errors in your system-user.dtsi. For example, if you are modifying an existing node, then you just need the &. If you want to add a node, then you need to do this within the DT structure /{ ... }; Also, there are alot of node that you are trying to modify that dont exist in the existing DT.
I have attached a zip file with a make that you can run for testing the DTG, and DTC more quickly.
For example, you will need to download the DTG from the github.
Once you do this, then make dts, and make include_dtsi DTSI_FILE=system-user.dtsi
Then to test, make compile
   As I mentioned in the original post I left errors in the system-user.dtsi on purpose to make the build flow to fail. However the build always succeeded. This was the case even after I did distclean, sstate and mrproper clean and even reinstalled Petalinux.
   But it finally worked after I created the project on a different machine from scratch. So looks like the original project was corrupted in some way. I have no idea how that happened.
   In any case thank you very much for looking into the issue.
Simon
OK, great. The main point I tried to make is how to better debug as doing this via trial and error in Petalinux can be painful. The script in the zip makes this alot easier.
