thenumberdevil
Difference between Xilinx Scaler Vs xilinx-vpss-scaler.c
Hi @florentw
                     What is the differerence between Xilinx Scaler Vs xilinx-vpss-scaler.c. ?
-nd
florentw
HI @thenumberdevil
Kindly do not tag me when starting a thread. This is a community forums you need to allow the community to answer the question.
There was previously a Scaler IP which is discontinued in later vivado version. The replacement is the VPSS IP.
Florent
