Dockerfile for Petalinux 2018.2
Trying to keep my development system clean, I created a docker (Ubuntu 16.04) to setup a Petalinux 2018.2
environment (UG1144, petalinux-env-check OK, ... no errors).  Attached is the Dockerfile and setup/installation/verification instructions.
Using the downloaded ZCU104 BSP, I get
"failed with exit code '134'"
during build, (see attached build.log).
I'd appreciate any comment or help.
thank you
wkr
Eddy
Re: Dockerfile for Petalinux 2018.2
Hi @debaere,
We haven't validated PetaLinux installation on Docker.
Sandeep
FWIW:
 I used dockerfile from
 https://github.com/z4yx/petalinux-docker
 and tested Petalinux 2018.2 with
 zc702 and zcu104 .bsp
 No errors !
wkr
Eddy
