Visitor martind1983
[ERROR] E: Sub-process /home/martin/petalinux-v2015.2.1-final/tools/packagemanager/bin/dpkg returned an error code (1)
Hello everybody
I have the problem which was already mentioned for older versions of PetaLinux tools which error by building kernel image.
I use linux ubuntu 14.04 LTS and PetaLinux 2015.2, I successfully created my target project "Tutorial_design", I acquired .hdf from exported from Vivado 2015.2 to my target project and configured project components in like kernel, rootfs...
When I want to build my kernel image I always get error
martin@martin-HP:~/NOC_research/PetaLinux/Avnet-Digilent-ZedBoard-2015.2/projects/Tutorial_design$ petalinux-build
INFO: Checking component...
INFO: Generating make files and build linux
INFO: Generating make files for the subcomponents of linux
INFO: Building linux
[INFO ] pre-build linux/rootfs/fwupgrade
[INFO ] pre-build linux/rootfs/peekpoke
[INFO ] pre-build linux/rootfs/uWeb
[INFO ] build linux/kernel
[INFO ] update linux/u-boot source
[INFO ] generate linux/u-boot configuration files
[INFO ] build linux/u-boot
[INFO ] build zynq_fsbl
[INFO ] Expanding stagefs
[ERROR] Errors were encountered while processing:
[ERROR] make[2]: *** [.pkg_stagefs] Error 255
[ERROR] make[1]: *** [sub_build_component_/none/packages-repo/single/plnx-repo] Error 2
ERROR: Failed to build linux
I already tried several tips from very similar threads. For example I tried to run it at least 3 times in turn if it does not change at third time but the result is the same ERROR.
I tried to add path to PetaLinux's debian package manager "dpkg" as I know that Ubuntu uses the same and it could cause theses errors but error still persists.
I even modified Petalinux sourcing script "settings.sh" used to source Petalinux tools and put path to PetaLinux dpkg to it.  You can it is included in my PATH variable after starting
~/NOC_research/PetaLinux/Avnet-Digilent-ZedBoard-2015.2/projects/Tutorial_design$echo $PATH
/home/martin/petalinux-v2015.2.1-final/tools/linux-i386/petalinux/bin:/home/martin/petalinux-v2015.2.1-final/tools/common/petalinux/bin:/home/martin/petalinux-v2015.2.1-final/tools/linux-i386/microblaze-xilinx-elf/bin:/home/martin/petalinux-v2015.2.1-final/tools/linux-i386/microblazeel-xilinx-linux-gnu/bin:/home/martin/petalinux-v2015.2.1-final/tools/linux-i386/arm-xilinx-gnueabi/bin:/home/martin/petalinux-v2015.2.1-final/tools/linux-i386/arm-xilinx-linux-gnueabi/bin:/home/martin/petalinux-v2015.2.1-final/tools/linux-i386/aarch64-none-elf/bin:/home/martin/petalinux-v2015.2.1-final/tools/linux-i386/aarch64-linux-gnu/bin:/home/martin/petalinux-v2015.2.1-final/tools/packagemanager/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/usr/local/programming
and also "which" command shows me that it should use dpkg in PetaLinux path
martin@martin-HP:~/NOC_research/PetaLinux/Avnet-Digilent-ZedBoard-2015.2/projects/Tutorial_design$ which dpkg
I do not even miss any libraries to run it  as some users in previous threads
ldd ~/petalinux-v2015.2.1-final/tools/packagemanager/bin/dpkg
    linux-vdso.so.1 =>  (0x00007ffc00bd1000)
    libselinux.so.1 => /lib/x86_64-linux-gnu/libselinux.so.1 (0x00007ffa1ef89000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007ffa1ebc4000)
    libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007ffa1e986000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007ffa1e782000)
    /lib64/ld-linux-x86-64.so.2 (0x00007ffa1f1ac000)
and also links are linked to correct version of libraries as this dpkg is 64bit version
file ~/petalinux-v2015.2.1-final/tools/packagemanager/bin/dpkg
/home/martin/petalinux-v2015.2.1-final/tools/packagemanager/bin/dpkg: ELF 64-bit LSB  executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.18, BuildID[sha1]=66e5f985c504f4afa8dfd593d59544769b99cf05, not stripped
but the aforementioned problem  still persists. I did not try this PATCH
https://forums.xilinx.com/t5/Embedded-Linux/2014-2-Image-Build-Processes-Error/m-p/510837#M10350
1. I do not thing it would help
2. I do not know where exactly I should patch it or write.
Thank you very much for help and advices
Br    Martin :)
Re: [ERROR] E: Sub-process /home/martin/petalinux-v2015.2.1-final/tools/packagemanager/bin/dpkg returned an error code (1)
@martind1983
Can you check the below  answer record and install 32-bit libraries required?
http://www.xilinx.com/support/answers/63034.html
Achutha
Visitor martind1983
Hi achutha
This is not good solution I have already met this solution this is missing 32-bit library and that is not my problem as  Petalinux 2015.2 is supports 64-bit completely I mean so, and I already tried your proposed solution without success.
However, I found out important probably bugy thing. When, after feetching my hdf file by tool "petalinux-config --get-hw-description -p <my_hw_description_file> I only configure system config what automatically shows up and then I build solution by "petalinux-build" everything is built fine and I get my "images" folder with all necessary files to boot system.
However, when I configure also kernel and rootfs by means of "petalinux-config -c kernel" and "petalinux-config -c rootfs" and I am going to build solution, then I get that error I specified before.
root@martin-HP:/home/martin/NOC_research/PetaLinux/tutorial_design/images/linux# petalinux-build
[INFO ] Cleaning packages
[INFO ] clean linux/rootfs/fwupgrade
[INFO ] clean linux/rootfs/peekpoke
[INFO ] clean linux/rootfs/uWeb
[INFO ] build system.dtb
[INFO ] Setting up stage config
[INFO ] Setting up rootfs config
[INFO ] Updating for cortexa9-vfp-neon
[INFO ] Updating package manager
Mainly in rootfs I add a lot of libraries and utilities which I will use in embedded linux. Maybe I do not know "dpkg" after that must do something and it is corrupted therefore that error.
Thank you for help :)
Br Martin
