Anonymous
Not applicable
Embedded Linux Kernal errors on ML510 for xsysace and mtab
After going through the steps posted on http://xilinx.wikidot.com I am able to successfully create, install and run Embedded Linux on the ML510 Evaluation board. The test applications seem to run but I get a few errors on the kernel printout that I don't understand:
[    1.836955] xsysace 83600000.sysace: Xilinx SystemACE revision 1.0.12
[    1.842905] xsysace 83600000.sysace: No CF in slot
[    1.852276] Error: Driver 'xsysace' is already registered, aborting...
[    1.865439] xsysace: registration failed; err=-16
And
/etc/mtab: cannot create
I believe this last error has to do with using the prebuilt ramdisk
V
Anonymous
Not applicable
Maybe a stupid question, but.... Do you have a CF card in the slot?
