Visitor deryai
Erase QSPI Flash Partition /dev/mtd Problem
We are using petalinux-v2017.2 for our custom board designed with zynq7045 SoC. We have two 64MB QSPI Flash(Spansion S25FL512S) in dual stacked configuration on it.
We have 4 partitions on qspi flash boot(zynq_fsbl.elf+system_wrapper.bit+u-boot.elf), bootenv, kernel(uImage+dtb) and spare. Rootfs is on EMMC. We are trying to update kernel partition image with the new one from rootfs with flashcp command.
Creating flash partition messages in kernel startup logs on below:
We've checked partiton again..
We are trying to erase kernel partition on below command:
After reading&checking the flash partiton(kernel_image.bin), it seems the kernel partiton is not erased.
Because of the flash erase problem , update kernel partition with the same image is failed.
root@petalinux_out:~# flashcp -v image.ub /dev/mtd2
BTW, we've checked the unlock of flash:
After searching on web, the reason of erase problem, uboot locks flash and erase & program from rootfs is not successful. unlock is not implemented in m25p80.c so unlock is not supported in kernel layer.
Is there any patch to solve this? How can we achieve update kernel parttion from rootfs ?
Best Regards,
Re: Erase QSPI Flash Partition /dev/mtd Problem
Hey @deryai,
I see at least two options here ...
  • Use the unlock command in u-boot to unlock the flash/partition
  • Patch the kernel to support unlocking
There have been several proposed patches for the unlock feature (google for m25p80.c unlock/unprotect) but it seems that they didn't make it into the kernel for whatever reason.
Hope this helps,
Herbert
Hey @deryai,
Hope this helps,
Herbert
Visitor deryai
Hi @@hpoetzl,
Thanks for your reply ...
Best Regards,
Derya
