ganyfun
Error When build kernel Image
Hi every body !
I want to port Linux on Microblaze, I follow the website : http://xilinx.wikidot.com it guide clearly about porting Linux on microblaze. Step by step I follow it :
 + generate xilinx.dts
+ download http://xilinx.wikidot.com/mb-gnu-tools
+ download http://git.xilinx.com/linux-2.6-xlnx.git master
But when I build the kernel with the command follow:
                           > make ARCH=microblaze simpleImage.xilinx
I have the problem:
make: microblaze-unknown-linux-gnu-gcc: Command not found
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/linux/version.h
CHK include/generated/utsrelease.h
CC kernel/bounds.s
/bin/sh: microblaze-unknown-linux-gnu-gcc: command not found
make[1]: *** [kernel/bounds.s] Error 127
make: *** [prepare0] Error 2
I don't know where I was wrong ? I did set the path to access tools and setup the environment variable for the Linux kernel build process with the following commands:
         export PATH=<dir where the tools are untarred>/microblaze-unknown-linux-gnu/bin:$PATH
        export CROSS_COMPILE=microblaze-unknown-linux-gnu-
Thanks for your help!
vneethv
make sure you can find microblaze-unknown-linux-gnu-gcc in the bin directory and its working by compiling a simple c file.
vneethv
ganyfun
thanks you so much, I really find the problem of it
taghlaoui
hi
please  can you help me more , I cant resolve this problem
