Error building u-boot
Hi all,
I'm experiencing an error when building u-boot as part of the overall ISE14.6 and PetaLinux v2013.04 build for Zynq. I've got a working toolchain, have compiled and deployed linux on my board target, and now I'm hit with this...
I'm following UG980, as per pg. 15 - Configuring Software Settings of the Hardware Project. I created the petalinux BSP, and selected stdin/out, DRAM, and ethernet with it. I then ran the whole command line PetaLinux process with the petalinux-copy-autoconfig command, and (eventually) run make here:
$ cd $PETALINUX/software/petalinux-dist
$ make
I got the following error when doing make:
... lots of build stuff...
[INFO ] Configuring u-boot
[INFO ] Building u-boot
[ERROR] arm-xilinx-linux-gnueabi-ld: error: required section '.rel.plt' not found in the linker script
[ERROR] make[1]: *** [u-boot] Error 1
[00:05] \ make: *** [u-boot] Error 255
If I remove the ethernet Value in the petalinux BSP (using SDK), this error goes away, but then u-boot isn't built with networking and isn't capable of running tftp etc. What is this error and how do I fix it?
Re: Error building u-boot
Hi Vadim,
Can you try to go to Uboot folder and run the following commands:-
$ make clean;
$ make mrproper
--HS
Hi Vadim,
$ make clean;
$ make mrproper
--HS
Worked like a champ. Thanks Hem!
