Visitor twlee2
Error: unable to open xlnk in Ubuntu 16.04
I am using ZCU102 board and its OS is Ubuntu 16.04. I got stuck with this issue for a while and NEED HELP!
I used SDSoC to create and build lab1.elf (Matrix Multiplication and Addition) and copied all files inside the sd_card directory to the root of an SD card.
After boot ZCU102 and run lab1.elf (./lab1.elf), I get the following error : enable to open xlnk
Is it because linux-xlnx doesn't include xlnk driver? If so, could you please help how to add xlnk driver in building Linux image?
In building Petalinux image there is a step to add device tree fragment for APF driver but I don't know how to add this in building Linux image...
Re: Error: unable to open xlnk in Ubuntu 16.04
As of v2018.2, xilinx linux kernel doesn't include APF driver as default(defconfig)
You have to build kernel image to include APF driver like this
Device Drivers -> Staging drivers
<*> Xilinx APF Accelerator driver ===> XILINX_APF=y
Device Drivers -> Staging drivers -> Xilinx APF Accelerator driver
[*] Xilinx APF DMA engines support ===> XILINX_DMA_APF=y
Then add this to your device tree
    xlnk {
        compatible = "xlnx,xlnk-1.0";
Visitor twlee2
Thank you so much for your comment and I got the idea of what to do.
Can you help with more details of how to add this kind of script? I am new to building of linux kernel.
I built my Linux Kernel from linux-xlnx (v2018.2) of github.
Which file should I modify to include xlnk driver by adding the script?
petalinux-config -c kernel for kernel configuration
vi <project directory>/project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi fore device-tree
Then petalinux-build
Visitor twlee2
I really appreciate your help. I was able to boot zcu102 with Ubuntu.
But, now I am having another problem and looking for your advice.
I used SDSoC to create and build lab1.elf (Matrix Multiplication and Addition) and copied all files inside the sd_card directory to the root directory of second partition of SD card. First partition of SD card includes BOOT.BIN and image.ub created by petalinux.
After boot ZCU102 and run lab1.elf (./lab1.elf), it shows
Testing 1024 iterations of 32x32 floating point mmultadd....
and hang there...
Please advise
