Ethernet DMA Bus Error
Historically, I have been able to boot Petalinux on my Ultrascale+ device from a Petalinux 2018.3 configuration. Since upgrading to either 2019.1 or 2019.2, there is a flurry of DMA bus errors and I need help figuring out how to resolve. My boot log is below,
# Loading kernel from FIT Image at 10000000 ...
Using 'conf@system-top.dtb' configuration
Trying 'kernel@1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x100000f8
Data Size: 18080256 Bytes = 17.2 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00080000
Entry Point: 0x00080000
Hash algo: sha1
Hash value: bf7b1d0d70fcc5b11e9d73532d585efdb40e9432
## Loading ramdisk from FIT Image at 10000000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: petalinux-user-image
Type: RAMDisk Image
Compression: gzip compressed
Data Start: 0x1114a850
Data Size: 27442816 Bytes = 26.2 MiB
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 64fadbf641c6753b694847edc3d930079de773e5
Trying 'fdt@system-top.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x1113e3fc
Data Size: 50062 Bytes = 48.9 KiB
Hash algo: sha1
Hash value: d9ede53845a8c5f0e45a2e6067ca6df5bc981cd9
Booting using the fdt blob at 0x1113e3fc
Loading Kernel Image ... OK
Loading Ramdisk to 775d4000, end 78fffe80 ... OK
Loading Device Tree to 0000000007ff0000, end 0000000007fff38d ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 4.19.0-xilinx-v2019.2 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP Fri Feb 7 05:19:24 UTC 2020
[ 0.000000] Machine model: xlnx,zynqmp
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[ 0.000000] bootconsole [cdns0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 256 MiB at 0x0000000067400000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with crng_init=0
[ 0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s53016 r8192 d28904 u90112
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516867
[ 0.000000] Kernel command line: earlycon console=ttyPS0,115200 clk_ignore_unused root=/dev/ram rw
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Memory: 1755548K/2096128K available (10748K kernel code, 632K rwdata, 5424K rodata, 832K init, 314K bss, 78436K reserved, 262144K cma-reserved)
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] irq-xilinx: /amba_pl@0/interrupt-controller@a0001000: num_irq=17, edge=0x0
[ 0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171015c90f, max_idle_ns: 440795203080 ns
[ 0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[ 0.008217] Console: colour dummy device 80x25
[ 0.012393] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399996)
[ 0.022754] pid_max: default: 32768 minimum: 301
[ 0.027452] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.034007] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.041886] ASID allocator initialised with 32768 entries
[ 0.046508] rcu: Hierarchical SRCU implementation.
[ 0.051483] EFI services will not be available.
[ 0.055835] smp: Bringing up secondary CPUs ...
[ 0.060503] Detected VIPT I-cache on CPU1
[ 0.060538] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.060866] Detected VIPT I-cache on CPU2
[ 0.060886] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.061187] Detected VIPT I-cache on CPU3
[ 0.061207] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.061251] smp: Brought up 1 node, 4 CPUs
[ 0.095672] SMP: Total of 4 processors activated.
[ 0.100345] CPU features: detected: 32-bit EL0 Support
[ 0.107451] CPU: All CPU(s) started at EL2
[ 0.109525] alternatives: patching kernel code
[ 0.115003] devtmpfs: initialized
[ 0.122267] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.126909] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.138252] xor: measuring software checksum speed
[ 0.177131] 8regs : 2375.000 MB/sec
[ 0.217159] 8regs_prefetch: 2052.000 MB/sec
[ 0.257186] 32regs : 2724.000 MB/sec
[ 0.297215] 32regs_prefetch: 2308.000 MB/sec
[ 0.297258] xor: using function: 32regs (2724.000 MB/sec)
[ 0.301562] pinctrl core: initialized pinctrl subsystem
[ 0.307474] NET: Registered protocol family 16
[ 0.311492] audit: initializing netlink subsys (disabled)
[ 0.316600] audit: type=2000 audit(0.268:1): state=initialized audit_enabled=0 res=1
[ 0.324218] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[ 0.324223] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.339150] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.359662] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.426926] raid6: int64x1 gen() 447 MB/s
[ 0.494972] raid6: int64x1 xor() 450 MB/s
[ 0.563003] raid6: int64x2 gen() 683 MB/s
[ 0.631049] raid6: int64x2 xor() 598 MB/s
[ 0.699075] raid6: int64x4 gen() 980 MB/s
[ 0.767111] raid6: int64x4 xor() 736 MB/s
[ 0.835151] raid6: int64x8 gen() 1163 MB/s
[ 0.903188] raid6: int64x8 xor() 758 MB/s
[ 0.971249] raid6: neonx1 gen() 736 MB/s
[ 1.039295] raid6: neonx1 xor() 879 MB/s
[ 1.107331] raid6: neonx2 gen() 1130 MB/s
[ 1.175391] raid6: neonx2 xor() 1172 MB/s
[ 1.243434] raid6: neonx4 gen() 1482 MB/s
[ 1.311476] raid6: neonx4 xor() 1417 MB/s
[ 1.379541] raid6: neonx8 gen() 1542 MB/s
[ 1.447563] raid6: neonx8 xor() 1459 MB/s
[ 1.447602] raid6: using algorithm neonx8 gen() 1542 MB/s
[ 1.451556] raid6: .... xor() 1459 MB/s, rmw enabled
[ 1.456487] raid6: using neon recovery algorithm
[ 1.461551] GPIO IRQ not connected
[ 1.464443] XGpio: gpio@a0004000: registered, base is 500
[ 1.469830] GPIO IRQ not connected
[ 1.473330] XGpio: gpio@a0004000: dual channel registered, base is 488
[ 1.480087] GPIO IRQ not connected
[ 1.483038] XGpio: gpio@a0005000: registered, base is 476
[ 1.488416] GPIO IRQ not connected
[ 1.491905] XGpio: gpio@a0005000: dual channel registered, base is 464
[ 1.498468] GPIO IRQ not connected
[ 1.501636] XGpio: gpio@a0006000: registered, base is 453
[ 1.507019] GPIO IRQ not connected
[ 1.510500] XGpio: gpio@a0006000: dual channel registered, base is 442
[ 1.517643] SCSI subsystem initialized
[ 1.520791] usbcore: registered new interface driver usbfs
[ 1.526080] usbcore: registered new interface driver hub
[ 1.531349] usbcore: registered new device driver usb
[ 1.536399] media: Linux media interface: v0.10
[ 1.540849] videodev: Linux video capture interface: v2.00
[ 1.546300] pps_core: LinuxPPS API ver. 1 registered
[ 1.551205] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.560299] PTP clock support registered
[ 1.564599] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver.
[ 1.571649] FPGA manager framework
[ 1.574979] Advanced Linux Sound Architecture Driver Initialized.
[ 1.581197] Bluetooth: Core ver 2.22
[ 1.584439] NET: Registered protocol family 31
[ 1.588835] Bluetooth: HCI device and connection manager initialized
[ 1.595151] Bluetooth: HCI socket layer initialized
[ 1.599994] Bluetooth: L2CAP socket layer initialized
[ 1.605022] Bluetooth: SCO socket layer initialized
[ 1.610222] clocksource: Switched to clocksource arch_sys_counter
[ 1.616005] VFS: Disk quotas dquot_6.6.0
[ 1.619846] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.631343] NET: Registered protocol family 2
[ 1.631791] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes)
[ 1.638772] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.646032] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 1.652724] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.659066] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 1.664991] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 1.671468] NET: Registered protocol family 1
[ 1.675909] RPC: Registered named UNIX socket transport module.
[ 1.681566] RPC: Registered udp transport module.
[ 1.686233] RPC: Registered tcp transport module.
[ 1.690905] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.697664] Trying to unpack rootfs image as initramfs...
[ 3.054662] Freeing initrd memory: 26796K
[ 3.055175] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 3.060345] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 3.068822] Initialise system trusted keyrings
[ 3.072334] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[ 3.079393] NFS: Registering the id_resolver key type
[ 3.083677] Key type id_resolver registered
[ 3.087817] Key type id_legacy registered
[ 3.091802] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 3.098470] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 4.192235] NET: Registered protocol family 38
[ 4.252472] Key type asymmetric registered
[ 4.252513] Asymmetric key parser 'x509' registered
[ 4.255837] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 4.263133] io scheduler noop registered
[ 4.267021] io scheduler deadline registered
[ 4.271305] io scheduler cfq registered (default)
[ 4.275932] io scheduler mq-deadline registered
[ 4.280429] io scheduler kyber registered
[ 4.314840] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 4.317096] arm-smmu fd800000.smmu: probing hardware configuration...
[ 4.321968] arm-smmu fd800000.smmu: SMMUv2 with:
[ 4.326544] arm-smmu fd800000.smmu: stage 1 translation
[ 4.331820] arm-smmu fd800000.smmu: stage 2 translation
[ 4.337096] arm-smmu fd800000.smmu: nested translation
[ 4.342288] arm-smmu fd800000.smmu: stream matching with 48 register groups
[ 4.349298] arm-smmu fd800000.smmu: 16 context banks (0 stage-2 only)
[ 4.355784] arm-smmu fd800000.smmu: Supported page sizes: 0x61311000
[ 4.362182] arm-smmu fd800000.smmu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.368583] arm-smmu fd800000.smmu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.377089] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 4.385865] brd: module loaded
[ 4.390319] loop: module loaded
[ 4.391229] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 4.394661] iommu: Adding device ff0f0000.spi to group 0
[ 4.400664] libphy: Fixed MDIO Bus: probed
[ 4.404869] tun: Universal TUN/TAP device driver, 1.6
[ 4.408734] CAN device driver interface
[ 4.412845] iommu: Adding device ff0c0000.ethernet to group 1
[ 4.418843] usbcore: registered new interface driver asix
[ 4.423498] usbcore: registered new interface driver ax88179_178a
[ 4.429546] usbcore: registered new interface driver cdc_ether
[ 4.435344] usbcore: registered new interface driver net1080
[ 4.440964] usbcore: registered new interface driver cdc_subset
[ 4.446846] usbcore: registered new interface driver zaurus
[ 4.452392] usbcore: registered new interface driver cdc_ncm
[ 4.458495] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.464471] ehci-pci: EHCI PCI platform driver
[ 4.469147] usbcore: registered new interface driver uas
[ 4.474192] usbcore: registered new interface driver usb-storage
[ 4.480683] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[ 4.487366] i2c /dev entries driver
[ 4.492332] usbcore: registered new interface driver uvcvideo
[ 4.496475] USB Video Class driver (1.1.1)
[ 4.501125] Bluetooth: HCI UART driver ver 2.3
[ 4.504958] Bluetooth: HCI UART protocol H4 registered
[ 4.510055] Bluetooth: HCI UART protocol BCSP registered
[ 4.515357] Bluetooth: HCI UART protocol LL registered
[ 4.520435] Bluetooth: HCI UART protocol ATH3K registered
[ 4.525816] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 4.532066] Bluetooth: HCI UART protocol Intel registered
[ 4.537408] Bluetooth: HCI UART protocol QCA registered
[ 4.542615] usbcore: registered new interface driver bcm203x
[ 4.548233] usbcore: registered new interface driver bpa10x
[ 4.553767] usbcore: registered new interface driver bfusb
[ 4.559216] usbcore: registered new interface driver btusb
[ 4.564637] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 4.570309] usbcore: registered new interface driver ath3k
[ 4.576167] sdhci: Secure Digital Host Controller Interface driver
[ 4.581850] sdhci: Copyright(c) Pierre Ossman
[ 4.586174] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.591940] iommu: Adding device ff160000.mmc to group 2
[ 4.597382] ledtrig-cpu: registered to indicate activity on CPUs
[ 4.603094] zynqmp_firmware_probe Platform Management API v1.1
[ 4.608841] zynqmp_firmware_probe Trustzone version v1.0
[ 4.637958] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22
[ 4.640666] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[ 4.645777] zynqmp_aes zynqmp_aes: AES Successfully Registered
[ 4.645777]
[ 4.653278] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[ 4.659435] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[ 4.665024] usbcore: registered new interface driver usbhid
[ 4.670327] usbhid: USB HID core driver
[ 4.676518] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[ 4.680923] usbcore: registered new interface driver snd-usb-audio
[ 4.687588] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 4.694622] Initializing XFRM netlink socket
[ 4.698530] NET: Registered protocol family 10
[ 4.703250] Segment Routing with IPv6
[ 4.706578] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 4.712755] NET: Registered protocol family 17
[ 4.716785] NET: Registered protocol family 15
[ 4.721198] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.734124] can: controller area network core (rev 20170425 abi 9)
[ 4.740251] NET: Registered protocol family 29
[ 4.744630] can: raw protocol (rev 20170425)
[ 4.748866] can: broadcast manager protocol (rev 20170425 t)
[ 4.754491] can: netlink gateway (rev 20170425) max_hops=1
[ 4.760179] Bluetooth: RFCOMM TTY layer initialized
[ 4.764790] Bluetooth: RFCOMM socket layer initialized
[ 4.769905] Bluetooth: RFCOMM ver 1.11
[ 4.773611] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.778881] Bluetooth: BNEP filters: protocol multicast
[ 4.784075] Bluetooth: BNEP socket layer initialized
[ 4.789003] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.794886] Bluetooth: HIDP socket layer initialized
[ 4.799950] 9pnet: Installing 9P2000 support
[ 4.804074] Key type dns_resolver registered
[ 4.808765] registered taskstats version 1
[ 4.812364] Loading compiled-in X.509 certificates
[ 4.817471] Btrfs loaded, crc32c=crc32c-generic
[ 4.828798] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 42, base_baud = 6249999) is a xuartps
[ 4.838239] console [ttyPS0] enabled
[ 4.841831] bootconsole [cdns0] disabled
[ 4.850262] of-fpga-region fpga-full: FPGA Region probed
[ 4.859457] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[ 4.865927] iommu: Adding device fd500000.dma to group 3
[ 4.871487] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[ 4.878525] iommu: Adding device fd510000.dma to group 4
[ 4.884002] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[ 4.891037] iommu: Adding device fd520000.dma to group 5
[ 4.896514] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[ 4.903553] iommu: Adding device fd530000.dma to group 6
[ 4.909032] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[ 4.916074] iommu: Adding device fd540000.dma to group 7
[ 4.921547] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[ 4.928587] iommu: Adding device fd550000.dma to group 8
[ 4.934065] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[ 4.941104] iommu: Adding device fd560000.dma to group 9
[ 4.946599] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[ 4.953637] iommu: Adding device fd570000.dma to group 10
[ 4.959213] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[ 4.966407] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[ 4.973517] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[ 4.980664] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[ 4.987783] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[ 4.994896] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[ 5.002008] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[ 5.009121] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[ 5.016239] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[ 5.024699] xilinx-psgtr fd400000.zynqmp_phy: PLL lock time out
[ 5.030613] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:8 protocol:4 pll_locked:no
[ 5.038353] zynqmp-display fd4a0000.zynqmp-display: failed to lock pll
[ 5.044888] zynqmp-display: probe of fd4a0000.zynqmp-display failed with error -110
[ 5.055195] m25p80 spi0.0: n25q512a (131072 Kbytes)
[ 5.060091] 3 fixed-partitions partitions found on MTD device spi0.0
[ 5.066441] Creating 3 MTD partitions on "spi0.0":
[ 5.071227] 0x000000000000-0x000002600000 : "boot"
[ 5.076614] 0x000002600000-0x000002680000 : "bootenv"
[ 5.082100] 0x000002680000-0x000008000000 : "kernel"
[ 5.087927] macb ff0c0000.ethernet: Not enabling partial store and forward
[ 5.095447] libphy: MACB_mii_bus: probed
[ 5.104139] TI DP83867 ff0c0000.ethernet-ffffffff:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0c0000.ethernet-ffffffff:00, irq=POLL)
[ 5.117188] macb ff0c0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0c0000 irq 30 (00:0a:35:00:22:01)
[ 5.127505] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[ 5.134083] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[ 5.140577] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[ 5.147070] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[ 5.153583] dwc3-of-simple ff9d0000.usb0: dwc3_simple_set_phydata: Can't find usb3-phy
[ 5.161886] iommu: Adding device fe200000.dwc3 to group 11
[ 5.167542] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
[ 5.173340] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 5.178835] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 5.186615] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000202010010
[ 5.196021] xhci-hcd xhci-hcd.0.auto: irq 65, io mem 0xfe200000
[ 5.202166] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 5.210431] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.217648] usb usb1: Product: xHCI Host Controller
[ 5.222516] usb usb1: Manufacturer: Linux 4.19.0-xilinx-v2019.2 xhci-hcd
[ 5.229208] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 5.234463] hub 1-0:1.0: USB hub found
[ 5.238222] hub 1-0:1.0: 1 port detected
[ 5.242345] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 5.247835] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 5.255499] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 5.262148] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 5.270310] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 5.278566] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.285776] usb usb2: Product: xHCI Host Controller
[ 5.290646] usb usb2: Manufacturer: Linux 4.19.0-xilinx-v2019.2 xhci-hcd
[ 5.297338] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 5.302477] hub 2-0:1.0: USB hub found
[ 5.306238] hub 2-0:1.0: 1 port detected
[ 5.310801] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
[ 5.318283] cdns-wdt ff150000.watchdog: Xilinx Watchdog Timer with timeout 10s
[ 5.354796] mmc0: SDHCI controller on ff160000.mmc [ff160000.mmc] using ADMA 64-bit
[ 5.370712] rtc_zynqmp ffa60000.rtc: setting system clock to 2103-11-05 00:01:46 UTC (4223664106)
[ 5.379577] of_cfs_init
[ 5.382038] of_cfs_init: OK
[ 5.384991] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.522693] mmc0: ADMA error
[ 5.525567] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.529617] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.531990] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00001002
[ 5.531992] mmc0: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000001
[ 5.531995] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[ 5.531998] mmc0: sdhci: Present: 0x01e70206 | Host ctl: 0x00000019
[ 5.532002] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 5.538522] clk: Not disabling unused clocks
[ 5.544932] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07
[ 5.544934] mmc0: sdhci: Timeout: 0x00000004 | Int stat: 0x00000000
[ 5.544939] mmc0: sdhci: Int enab: 0x02ff008b | Sig enab: 0x02ff008b
[ 5.551375] ALSA device list:
[ 5.557787] mmc0: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 5.557789] mmc0: sdhci: Caps: 0x35ecc881 | Caps_1: 0x00002007
[ 5.557792] mmc0: sdhci: Cmd: 0x0000083a | Max curr: 0x00000000
[ 5.557796] mmc0: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0xffffffff
[ 5.564223] No soundcards found.
[ 5.570642] mmc0: sdhci: Resp[2]: 0x328f5903 | Resp[3]: 0x00d00f00
[ 5.570644] mmc0: sdhci: Host ctl2: 0x00000000
[ 5.570648] mmc0: sdhci: ADMA Err: 0x00000001 | ADMA Ptr: 0x00000000fffff200
[ 5.574997] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 5.581326] mmc0: sdhci: ============================================
[ 5.659248] cfg80211: failed to load regulatory.db
[ 5.659265] mmc0: error -5 whilst initialising MMC card
[ 5.669902] Freeing unused kernel memory: 832K
[ 5.694251] Run /init as init process
INIT: version 2.88 booting
[ 5.727716] mmc0: ADMA error
[ 5.730580] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.737003] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00001002
[ 5.743427] mmc0: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000001
[ 5.749850] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[ 5.756273] mmc0: sdhci: Present: 0x01f70206 | Host ctl: 0x00000019
[ 5.762696] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 5.769120] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00004e47
[ 5.775543] mmc0: sdhci: Timeout: 0x00000004 | Int stat: 0x00000000
[ 5.781966] mmc0: sdhci: Int enab: 0x02ff008b | Sig enab: 0x02ff008b
[ 5.788389] mmc0: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 5.794813] mmc0: sdhci: Caps: 0x35ecc881 | Caps_1: 0x00002007
[ 5.801236] mmc0: sdhci: Cmd: 0x0000083a | Max curr: 0x00000000
[ 5.807659] mmc0: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0xffffffff
[ 5.814083] mmc0: sdhci: Resp[2]: 0x328f5903 | Resp[3]: 0x00d00f00
[ 5.820505] mmc0: sdhci: Host ctl2: 0x00000000
[ 5.824933] mmc0: sdhci: ADMA Err: 0x00000001 | ADMA Ptr: 0x00000000fffff200
[ 5.832049] mmc0: sdhci: ============================================
[ 5.838543] mmc0: error -5 whilst initialising MMC card
[ 5.907184] mmc0: ADMA error
[ 5.910067] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 5.916499] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00001002
Starting udev[ 5.922928] mmc0: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000001
[ 5.930483] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[ 5.936906] mmc0: sdhci: Present: 0x01f70206 | Host ctl: 0x00000019
[ 5.943503] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 5.949927] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x0000f447
[ 5.956359] mmc0: sdhci: Timeout: 0x00000004 | Int stat: 0x00000000
[ 5.962797] mmc0: sdhci: Int enab: 0x02ff008b | Sig enab: 0x02ff008b
[ 5.969240] mmc0: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 5.975672] mmc0: sdhci: Caps: 0x35ecc881 | Caps_1: 0x00002007
[ 5.975821] udevd[1765]: starting version 3.2.5
[ 5.982095] mmc0: sdhci: Cmd: 0x0000083a | Max curr: 0x00000000
[ 5.982097] mmc0: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0xffffffff
[ 5.982100] mmc0: sdhci: Resp[2]: 0x328f5903 | Resp[3]: 0x00d00f00
[ 5.982104] mmc0: sdhci: Host ctl2: 0x00000000
[ 5.986935] random: udevd: uninitialized urandom read (16 bytes read)
[ 5.993040] mmc0: sdhci: ADMA Err: 0x00000001 | ADMA Ptr: 0x00000000fffff200
[ 5.993042] mmc0: sdhci: ============================================
[ 5.993151] mmc0: error -5 whilst initialising MMC card
[ 5.999562] random: udevd: uninitialized urandom read (16 bytes read)
[ 6.042013] random: udevd: uninitialized urandom read (16 bytes read)
[ 6.052713] udevd[1766]: starting eudev-3.2.5
[ 6.088062] mmc0: ADMA error
[ 6.090944] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 6.097375] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00001002
[ 6.103798] mmc0: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000001
[ 6.110221] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[ 6.116644] mmc0: sdhci: Present: 0x01e70206 | Host ctl: 0x00000019
[ 6.123068] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 6.129491] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x0000e8c7
[ 6.135914] mmc0: sdhci: Timeout: 0x00000004 | Int stat: 0x00000000
[ 6.142337] mmc0: sdhci: Int enab: 0x02ff008b | Sig enab: 0x02ff008b
[ 6.148760] mmc0: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 6.155184] mmc0: sdhci: Caps: 0x35ecc881 | Caps_1: 0x00002007
[ 6.161607] mmc0: sdhci: Cmd: 0x0000083a | Max curr: 0x00000000
[ 6.168031] mmc0: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0xffffffff
[ 6.174454] mmc0: sdhci: Resp[2]: 0x328f5903 | Resp[3]: 0x00d00f00
[ 6.180876] mmc0: sdhci: Host ctl2: 0x00000000
[ 6.185304] mmc0: sdhci: ADMA Err: 0x00000001 | ADMA Ptr: 0x00000000fffff200
[ 6.192421] mmc0: sdhci: ============================================
[ 6.198944] mmc0: error -5 whilst initialising MMC card
Configuring packages on first boot....
(This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
INIT: Entering runlevel: 5
Configuring network interfaces... [ 6.979663] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc: started, v1.29.2
udhcpc: sending discover
[ 9.038845] macb ff0c0000.ethernet eth0: link up (1000/Full)
[ 9.044529] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9.062329] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.068689] arm-smmu fd800000.smmu: Unhandled context fault: fsr=0x402, iova=0x1007100050070, fsynr=0x10000, cb=1
[ 9.079444] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.085787] arm-smmu fd800000.smmu: Unhandled context fault: fsr=0x402, iova=0x1007100050070, fsynr=0x10000, cb=1
[ 9.096512] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.102866] arm-smmu fd800000.smmu: Unhandled context fault: fsr=0x402, iova=0x1007100050070, fsynr=0x10000, cb=1
[ 9.113590] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.119934] arm-smmu fd800000.smmu: Unhandled context fault: fsr=0x402, iova=0x1007100050070, fsynr=0x10000, cb=1
[ 9.130659] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.137008] arm-smmu fd800000.smmu: Unhandled context fault: fsr=0x402, iova=0x1007100050070, fsynr=0x10000, cb=1
[ 9.147722] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.154064] arm-smmu fd800000.smmu: Unhandled context fault: fsr=0x402, iova=0x1007100050070, fsynr=0x10000, cb=1
[ 9.164777] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.171120] arm-smmu fd800000.smmu: Unhandled context fault: fsr=0x402, iova=0x1007100050070, fsynr=0x10000, cb=1
[ 9.181834] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.188177] arm-smmu fd800000.smmu: Unhandled context fault: fsr=0x402, iova=0x1007100050070, fsynr=0x10000, cb=1
[ 9.198890] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.205233] arm-smmu fd800000.smmu: Unhandled context fault: fsr=0x402, iova=0x1007100050070, fsynr=0x10000, cb=1
[ 9.215945] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.222289] arm-smmu fd800000.smmu: Unhandled context fault: fsr=0x402, iova=0x1007100050070, fsynr=0x10000, cb=1
[ 9.233003] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.239823] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.246633] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.253445] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.260251] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.267056] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.273861] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
[ 9.280666] macb ff0c0000.ethernet eth0: DMA bus error: HRESP not OK
these eth0: DMA bus error messages go on forever. Any help would be appreciated.
Re: Ethernet DMA Bus Error
Hi @jim.henderson
Can you try writing 0xFF to 0xff180408 once you boot till u-boot or after FSBL and see if that helps in booting the linux without any issues?
Best Regards
Shabbir
What is the best way to do that during the boot process?
So I found that instead of writing those values out during the boot process, I did something equivalent for our gigabit ethernet which was to modify the firmware to set CCI to be enabled as shown here, https://forums.xilinx.com/t5/Embedded-Linux/Enable-cache-memory-for-xilinx-axi-dma/td-p/993722. Apparently if you do this and use Petalinux 2018.3 then you have problems with your gigabit ethernet, but in 2019.2 it is required for the ethernet to work.
