ritanagar
Ethernet support in Linux running on PPC440(virtex5)
Hello sir,
I successfully added Ethernet , but how can I load my application on board using ethernet, I laso go through the XAPP1026  but  my  RFS asking for passwd , I taken Ramdisk.image from Xilinx wiki , Plz help me how can I load my application on Target board.
Anonymous
Not applicable
1. Add the application files to your ramdisk
2. mount an NFS volume and access the file over the network
3. TFTP/FTP to/from the target system.
ritanagar
Sorry sir , I have not explained that I made linux image and running on powerpc,after running Root:> prompt comes there I assigned IPCONFIGURATION to board and connect it to windows system (Hyperterminal).Both are connected(Borad) and PC.LAN connection is established.
Ya I already done run my application on Linux running on powerpc but I made LINUX IMAGE with RFS(ramdisk.image) , copy my application in ramdisk then recompile linux and running it.
But I want that through ethernet the application should transfer to ramdisk from outside.
Plz help me hw can I do this.
Anonymous
Not applicable
please see points 2 and 3 above.
Terry
ritanagar
Hello sir,
I tried a lot I m not able to mount also.Actually I included the ntfs,nfs file system support while configuring the kernel , but
root:>fdisk -l | grep ntfs
fdisk not found
Plz help me how can i remove this.Ya know we can mount windows partition in linux but sir linux is running on hyperterminal (ported) totally confusions.Plz help me to sort out this problem, I will be very thankful to u.
ritanagar
Also this thing I alreday done,I add application in ramdisk and run that.But for that I can run only that application.My requierment is to run any application , cross-compiled it on linux and transfer it on target linux.Thanks sir.
ritanagar
Hello sir,Now I m able to transfer my application though Ethernet usimg ftp.But whatever application I m executing their dont run.
I made small helloworld program, crosscompile it and then then copy it to c:/ drive as Im using windows hyperterminal.
Nw I can view my exe program in linux.But when i tried to execute it its not running.It showing error like.ERROR:  program can`t execute.
Plz help me to sove this.
Anonymous
Not applicable
I'm sorry, I really can't follow what you're trying to do.  You need to cross compile in the same environment where you built your kernel. You will need to start by specifying -static  to simplify things, then add libraries later as necessary to reduce program size.
I don't know what you're trying to say when you say "I'm using windows hyperterminal" - this is irrelevant..  Do you have a Linux environment to use for your development, or are you trying to do all of this under windows.
Terry
ritanagar
Thanks sir for your response.
I m working only with RHEL5 with xilinx12.2 with use ethernet to get the licience from server , I m making image by cross compiler with ELDK .Actually in my PC I dont have UART port , so I cant use the minicom to see the output of my linux image.Using Xmd I m downloading my LINUX IMAGE for the target Board Virtex440-ml507.I am just connecting my rs232 with windowsxp so that I can use hyperterminal to see the result.
Problem is that I want to run any application on linux run on FPGA.So previously I put the application in ramdisk.image (RFS) and remake linux image, and when I load that image I can see my application where I put my file.It ran easily.But From this way every time I have to uncompress the ramdisk image, put the cross-compiled application and make the linux image again.
I want that any application I can run on this linux.Some of my known is working with ARM so he can crosscompile his C application on his federo system and copy that application in pendrive and plug it in ARM usb port.There he copy that in ramdisk and run that application , using Ethernet also (ftp) can also transfer file to board.
I add ethernet to transfer my file.From pc directly Im downloading my image to FPGA .So I cant transfer any other file using xmd that time.So thats y I added Ethernet.
Yes I m executing my application in the same way as u said.In hello folder hello.c program is there.
<!-- @page { size: 8.5in 11in; margin: 0.79in } P { margin-bottom: 0.08in } -->
[root@localhost hello]# source /cad/eldk/eldk_init ppc_4xx
[root@localhost hello]# export ARCH=powerpc
[root@localhost hello]#ppc_4xx-gcc –static hello.c –o hello
But its not executing on target Board where linux is running when transfer from ethernet.I am connecting ethernet cable also to Xp system.
Hope I m able to explain.......................Plz reply
