borowskk
Expected boot time...
I have linux built and running on the ML605 by following the steps at http://xilinx.wikidot.com/microblaze-linux. However, the boot is very slow. With the complete ramfs it takes nearly 20 minutes from the time I execute the run command from XMD til I see the console. It gets stuck on the second line "Ramdisk addr 0x00000003, ..." I have a simple hardware setup with the minimal timer, uart, mmu microblaze, etc.
Where should I start in trying to make this thing come up faster? I assume it should boot much quicker.
linnj
No it shouldn't take that long to boot.
Does it actually boot to a console as it's not clear from what you say, "gets stuck on the 2nd line....".
If it doesn't really boot I would suspect the device tree is not right.
borowskk
It does eventually boot to the console. Where linux seems to function correctly.
borowskk
I believe the problem was a result of me not adding instruction and data caches in the base system builder. I compared your .mhs file to mine and that was the most significant difference. Once I rebuilt with caches it boots in about 30 seconds.
linnj
Good job!   I should have mentioned that, didn't think about it.
Thanks for the feedback saying you got it to work.
